BillaBoo Guest
Posted: Thu Dec 16, 2004 9:57 pm Post subject: Changing to 2nd gear makes nasty noices. |
I got a 1992 33 QV, its a nice car. But when do a fast change to 2nd gear, the gearbox gives out some nasty noices. I`ve been told its bad synchronized.
ANY way to fix this without replacing the gearbox?
thanks |
LDA Alfa 33
Posted: Thu Dec 16, 2004 10:27 pm Post subject: |
yeh, rebuild it!
some people do it them selves. but i know nothing of the insides of gearboxes so i had mine rebuilt last year. my car is a 33 perm 4 so its a slightly diffrent box but not much.
the cost was about £700 for a full rebuild of my box. well worth the effort. but even with a tottaly rebuilt box, if you stuff the gears in too hard and fast it will only take a few thousand miles to get it to make nasty noises again.
i dont know if there are any upgraded internal parts for the box, but your best best is to change slowly or double clutch. i use the slow change method and i never get a crunch. its not a modern car, take care of it!
rjbevan Alfasud
Posted: Fri Dec 17, 2004 12:29 am Post subject: |
If you do get the box rebuilt then it is worth getting some special transaxle oil to put in it. There are a few posts on this subject, suggest you search the archives.
Richard |
BillaBoo Guest
Posted: Mon Dec 20, 2004 10:09 pm Post subject: |
rebuilt? too expensive.. i`m looking for a cheaper solution.
And i`ve been told that it gets f****d after a while anyway.
Gonna see if i can find a different gearbox that i can fit into the 33, or just change the synchro`s that cause the problem. if possible.
thanks for replies |
LDA Alfa 33
Posted: Tue Dec 21, 2004 1:43 pm Post subject: |
are there any uprated syncros that could be installed? or do we have to put up with the rubbish stock ones?
would a renualt 21 gerbox fit with a modified bell housing? same basic shape and a front wheel drive box as the alfa one but slighly larger. still 5 gears. they use them in the lotus esprit (or did till they ran out of new boxes and stopped building esprits )
