Posted: Thu Feb 19, 2009 4:19 pm Post subject: |
Lol.
Look on bright side this way you will have no problem reading dials when you turn 80+. _________________ Tino Vatavuk
Greek Alfasud
Posted: Fri Feb 20, 2009 8:29 pm Post subject: |
They are printed in an A4 page and they got magnified... |
Posted: Sat Apr 04, 2009 6:53 pm Post subject: |
I reckon they might fit Al |
Posted: Thu Apr 09, 2009 1:35 pm Post subject: |
I fitted the dials last night, but my camera phone battery was flat. I will post a pic up later, they look the nuts btw
I cant decide if i should stick them onto some green plastic, onto the clear plastic in the dials or onto the original black dials, suggestions please.
I had to check the MPH and RPM was ok. I let the car idle and pushed on the needle and it is correct, rev limiter came in at 6.5k then the car cut out and i was srtanded for a while, another story.
The MPH was 10 MPH out, i put the needle on at 0 MPH, you need to put it on at 10 MPH. _________________ x2 33 16v
Posted: Thu Apr 09, 2009 6:06 pm Post subject: |
Looks nice Al. Did you not bother with the chrome rings in the end? |
Posted: Thu Apr 09, 2009 6:32 pm Post subject: |
Doh! i forgot, i will order them next week lol, thanks for reminding me and thanks for the nice comment.
Any one interested in buying some? I will take a pic in the dark soon. _________________ x2 33 16v
Posted: Thu Apr 09, 2009 7:31 pm Post subject: |
Is that really your car Al?, I know you don't use it much but your mileometer reading 0? , or is that a new speedo? or are you fiddling it lol. _________________ PHAT 33 |
Posted: Thu Apr 09, 2009 10:22 pm Post subject: |
I dropped the clocks and it went back to 0 .
No, i kid, photoshop, i need help in setting my other dials to match my car, that one i did drop when i tried to put them forward to match mine and now i dont know what to do. Any suggestions or the correct way to set a clock. _________________ x2 33 16v
Posted: Fri Apr 10, 2009 11:15 pm Post subject: |
Could someone please scan the speed dial from a ser 3 as mine is cruddy. I want to add the KPH. Please do it as a BMP and email it to me, or host it and supply a link, thanks. _________________ x2 33 16v
Posted: Tue Apr 14, 2009 8:44 pm Post subject: |
Here you can see the dark parts, i don't mind, shall i put them on some black backing to simulate them being stuck on the dials? _________________ x2 33 16v
Posted: Thu Apr 16, 2009 5:56 pm Post subject: |
Is it my eyes playing up Al or can I see the old dials showing through especially on the temp/ fuel gauge?
I like the LED lighting though. Sure makes your dials easier to see in the dark. |
JeremyC Gold Cloverleaf
Posted: Thu Apr 16, 2009 8:22 pm Post subject: |
I can certainly see something peeping through but it doesn't look like an old dial to me!!!!!
Where's a mod when you need one, I only ate half an hour ago! _________________ '93 Black 33 1.7 16v |
Posted: Fri Apr 17, 2009 3:27 am Post subject: |
lee16v wrote: |
Yup, the temp and fuel dials are from the ser 3 set, i didnt realise there was a difference, there curved on the ser 2 and straight on the ser 3, i will get some ser 2 fuel and temp dials done.
Anyone interested and what do you think?
Should i stick onto some green opaque plastic or onto the original dials?? _________________ x2 33 16v
Posted: Fri Apr 17, 2009 12:09 pm Post subject: |
BigAl wrote: |
Should i stick onto some green opaque plastic or onto the original dials?? |
Not sure I get what you mean Al?
JeremyC wrote: |
I can certainly see something peeping through but it doesn't look like an old dial to me!!!!! |
Keith was worried these tossers would return and voila..... |
Posted: Fri Apr 17, 2009 10:01 pm Post subject: |
Hey Lee,
If i stuck the dials onto some green plastic, when the lights were turned on it would back light and illuminate the dials in green. If i stuck the dials onto the original black dials there would be no back light and only light from the side would be visible "currently white" as the green covers for the bulbs appears blue when LED's are used. _________________ x2 33 16v
Posted: Sat Apr 18, 2009 6:04 pm Post subject: |
Ah, I see.
Looks good white to me. Easy to see and you may lose some of that visability with green dials? |
Posted: Sat Apr 18, 2009 7:20 pm Post subject: |
BigAl wrote: |
Could someone please scan the speed dial from a ser 3 as mine is cruddy. I want to add the KPH. Please do it as a BMP and email it to me, or host it and supply a link, thanks. |
Posted: Wed Apr 22, 2009 11:25 pm Post subject: |
Hey guys, i got my chrome rings today, a few problems.
I don't want to give any negative feedback until i have given them a chance to rectify the problems.
I took the clear plastic off my console and put the rings in place. The first thing I noticed is that the inside of al the rings are not deep enough to do as the instructions say and fold over with a pen from the back side of the fascia. On the larger two rings there is at least a 5mm gap.
The second thing is that the front of the two larger rings touch the inside of the front glass at the bottom, which is a clear plastic. I only placed the cover on and pressed it in place and that damaged the cover and caused spider cracks to form. If I had screwed down the front cover, it would have caused the cover to crack and brake.
There seems to be a design fault or the wrong ones were sent.
There is less than a 1mm gap between the front of the fascia and the plastic cover.
apart from very fast delivery i am impressed.
I'll keep you updated. _________________ x2 33 16v
Posted: Fri Apr 24, 2009 6:34 pm Post subject: |
update
Theres only a 1.3 mm gap between the fascia and the clear plastic cover, the dials are 3mm.
I emailed the distrubitor and am waiting for a responce, they said that they have never had any problems, i dont know anyone else that has bought any. Even the pic advertising them bowes out. _________________ x2 33 16v
Posted: Fri Apr 24, 2009 8:43 pm Post subject: |
Al, could you space the plastic cover off by 3 mm to resolve the issue?. I fitted these several months back and had no problems apart from having to bond the rings in place. _________________ PHAT 33 |
Posted: Fri Apr 24, 2009 9:37 pm Post subject: |
Hey Iain, i did have a play around with doing just that, and tried rubber o rings between the plastic cover and facia. Another problem then arises, being that the screws aren’t long enough. A paying customer shouldn’t have to source screws and go through all this. I am annoyed as it is, as it has damaged my clear plastic. From a design point, a customer shouldn’t have to do all this and they should know that there product design could be better. They said that no one else has complained. Could you point out that you had the same issue please, the more voices the merrier.
They gave me a link to other instructions and I don’t think bonding will be necessary http://www.youtube.com/watch?v=SxEStkJgSYM I haven’t done this yet in case they redesign with a flat edge at the bottom or make the protruding amount no more than 1.3mm.
Even in their picture you can see that the clear plastic cover bows outwards. |
