putting front koni's
neo
PostPosted: Tue Apr 08, 2003 8:47 pm    Post subject: putting front koni's Reply with quote
Hi !
I've just finished installing new front koni sport on my alfa 33. If anyone did it, can you tell me if you had problems with that screw that holds the shock and the housing (old shock) together (on the bottom of the housing)?
Mine is unscrewing when I drive on bumpy roads.
Scott Sander
PostPosted: Tue Apr 08, 2003 9:42 pm    Post subject: Reply with quote
I have fitted yellow koni's to my 16V. There is an aluminium spacer/washer and then another locking washer as well to fit. You need to torque the bolt up to about 80-90 Nm as per the instructions. Then check the torque a week later. I have not had any problems. Rolling Eyes
Scott Sander
http://www.sanderfamily.com
neo
PostPosted: Wed Apr 09, 2003 10:25 am    Post subject: re Reply with quote
Should I check the torque when the shock is mounted on the car and loaded or do I have to remove the shock from the car?
Does it make any difference?
btw. How much did you stiffen your shocks? I have OMP lowered springs and I've stiffened the shocks 1 half turn. How can I tell if the rebound is to stiff or to weak?
Thanks!
Scott Sander
PostPosted: Wed Apr 09, 2003 10:40 am    Post subject: Reply with quote
Fitted should be fine, with the wheels under load.
All round are 1/3 turn, although I'm thinking of givin the rear a bit of a tweak.
I'm no professional when it comes to setting the car up, but if the rebound is too much, you will have the car diving under bumpy ground. This is because the the shock does not have time to return to its normal position before being depressed further from the next bump.
I remember reading about setting the car shocks up on a web site, but can't remember the address.
Setting the front and rear correctly can be difficult and it also depends on the drivers preference.
Scott Sander
