thermostat
johnboy
PostPosted: Sat Dec 27, 2003 6:26 pm    Post subject: thermostat Reply with quote
Merry christmas people
has any one changed a thermostat on a 16v before? is it a complete unit or can you take it apart, as it look's like it's silled?
any help would be very helpful Cool
all the best john
WODA WE NEED? MORE POWER!!
1999 freestyle superjet
BILL
PostPosted: Sat Dec 27, 2003 8:50 pm    Post subject: Reply with quote
Merry Christmas to everyone Very Happy
I have changed my thermostat two weeks ago,the mechanik told me that both the 8V and 16V use the same part.He fixed three cars ( 2 16V and 1 8V) at the same week,i guess they last for about 10 years.Now i finally have hot air inside the car ( a frosty winter in Greece),and the temp is between 80 and 90 all the time.As i saw the thermostat is sealed and i dont think you can open it and seal it back .Its was not very expensive ,it cost me 45 euro.
Happy new year Very Happy Very Happy Very Happy
BILL
nickus?
PostPosted: Sat Dec 27, 2003 9:32 pm    Post subject: Reply with quote
Changed mine last week on a P4 , it's a sealed unit cost about £23 I think!
Seasons greetings and all that!
Nick
gritsop
PostPosted: Sun Dec 28, 2003 2:14 am    Post subject: Hi Reply with quote
The thermostat in the late 33's is a compact barrel like device that is thrown away as a whole when it stucks open. It contains a gas ampoule which determines the opening temp. By this way when the gas escapes from the ampoule this means the end of the thermostat's life; the good news is that the thermostat is designed to stay open if it fails . So you dont have the risk to overheat your engine.
Replacing a thermostat however can be sometimes difficult if your car is equipped with power assisted steering. If so you must remove the intake manifold in order to gain access to the mounting bolt and the clamps which are hidden.
If there is no PAS then it is more easy to replace it.
Also mine was replaced exactly 2 years ago and it was the first time I needed to replace it;indeed they last about 10 years as Bill also said. I had to remove the intake manifold and also replace the manifold gaskets . The thermostat cost me about 25? and the gaskets no more than 1.5? and the rest the work was done by the mechanic ; total about 50?
Finally having the car the proper running temperature is a VERY important issue because otherwise the car has increased gas consumption which comes from the fact that since the engine is cold the gas mixture has to be richer and richer.
My Xmas regards,
Thanassis Gritsopoulos
johnboy
PostPosted: Sun Dec 28, 2003 11:22 am    Post subject: Re: Hi Reply with quote
Hi guy's
Thank's for your help,thought it was silled. plus i did'nt use the power steering,so it should be an easy job,but then again, no job is ever easy on an alfa in the end Wink plus ive seen one on ebay so i will see how much it goes for now i have a ruff idear of prises.thank's again for your help.
all the best john Cool
Scott Sander
PostPosted: Sun Dec 28, 2003 9:23 pm    Post subject: Reply with quote
While you are changing the thermostat have a look at the pipes going to it. They are getting on a bit and with the disturbance they are about to get, they might split.
Scott Sander
http://www.sanderfamily.com
johnboy
PostPosted: Mon Dec 29, 2003 1:01 pm    Post subject: Reply with quote
Thanks scott
that happened to me when i stripped the engine,the center pipe split.
all the best john
Eddie W
PostPosted: Tue Dec 30, 2003 8:57 am    Post subject: Reply with quote
Hi guys
I've replaced two of ours with the 2piece Sud unit and a thermostat to fit at a fraction of the price of the one piece unit out here.
Regards Eddie
