Rear Brake Caliper (P4)
JamesD
PostPosted: Sun Jan 25, 2004 12:33 pm    Post subject: Rear Brake Caliper (P4) Reply with quote
Does anyone have any info on the rear disc brake caliper fitted to the P4? Particularly the hand brake adjustment when changing pads. My left rear caliper is not responding to the hand brake, and I haven't been able to push the piston back into the housing to free the (worn) disc. It took long enough to get the caliper off after some mongrel used the wrong grade of locktite to glue the bolts in.......
Also, any clues for the supplier of rear discs?
JamesD
Brisbane, Aust.
33S16VP4.
PostPosted: Mon Jan 26, 2004 7:27 pm    Post subject: Reply with quote
The piston needs to be rotated and pushed in to get it to retract. It might be easiest to undo the bleed screw a tad while you do this.
Buck Bundy
PostPosted: Tue Jan 27, 2004 12:00 am    Post subject: Disc stuck? Reply with quote
I doubt you will be able to retract the piston if the disc is still stuck.
(I think I read that right!)
If that's the case I don't think you have much option other than brute force and ingnorance.
Buck
Sprint Veloce 1.5 - Ebay £310!!! (In need of TLC)
JamesD
PostPosted: Tue Jan 27, 2004 11:51 am    Post subject: P4 Rear Brakes Reply with quote
Thanks, I had hoped for an external adjustment like the 'Sud front brake calipers. I might have to go the ignorance route (after trying cracking the bleed nipple)! The real problem is the disc is worn and the pads fit nicely into the groove - I need to push back the piston 5mm or so or grind off the edge of the disc after finding replacements.
James
33S16VP4
