teefivonine Alfa Arna
Posted: Wed Mar 31, 2004 3:00 pm Post subject: IDF Carbs |
I could do with checking the idle jets for blockages on my 1987 33 Veloce Weber IDF 40's. I found a diagram on the web showing their location but they dont appear to be in the same place on my carbs ?? Can somebody enlighten me please. |
Serpent33 Alfa Sprint
Posted: Wed Apr 07, 2004 12:22 pm Post subject: Re: IDF Carbs |
teefivonine wrote: |
Are yours weber as well? _________________ Each time I speed I say, "Dear lord, make me fast and accurate..." |
Posted: Wed Apr 07, 2004 11:54 pm Post subject: |
Should just undo the top of the carb and the idle and main jets should be there for you to unscrew out. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
rjbevan Alfasud
Posted: Fri Apr 09, 2004 6:06 pm Post subject: |
I've just checked my idle jets and 2 of them were blocked up. After removing the top elbow, I noticed that the main jets are very prominent (as they stick out about an inch) whilst the idle jets are adjacent but are below the top of the carb body (so they are easily missed!).
I have a fuel filter that looks very clean but is the petrol reacting with the aluminium of the carb to block the idle jets? If so is there an easier way of keeping the jets clean (such as adding something to the petrol tank)?
Richard |
Posted: Wed Apr 14, 2004 5:02 pm Post subject: |
rjbevan wrote: |
Richard |
The one sticking out is the air corrector jet. Unscrew it and the main jet is right at the bottom end. Please take care not to over tighten and keep it clean. Not to under tighten as well.... good luck. _________________ Each time I speed I say, "Dear lord, make me fast and accurate..." |
