36 drla float height
pete nz 1.5 s2
PostPosted: Mon Apr 26, 2004 10:47 pm    Post subject: 36 drla float height Reply with quote
Please some one ,floats are in transit from Auckland now.Can't find my old Haynes manuel.
float height = ?
see previous post
thanks
quest
PostPosted: Tue Apr 27, 2004 6:29 am    Post subject: Floats Reply with quote
At work now, checking from book when getting home.
TimoJ
Ps. Do You have a good supply of spares for drla? Heard that new are not made anymore, tried to buy 4omm drla:s but not found.
Going to buy all parts for spare..
Eddie W
PostPosted: Wed Apr 28, 2004 5:39 am    Post subject: Reply with quote
Hi Pete, 5-6mm. Measure with the carb top held vertically and the float just touching thi spring loaded part of the needle valve. I made myself a spacer that is filed to 5.5mm thick, you can then see if there is clearance or movement of the float when you slide it betweenthe float and gasket and adjust accordingly. Much easier than trying to measure it in any way.
Regards Eddie
Keith, but not here
PostPosted: Sun May 16, 2004 11:23 pm    Post subject: Reply with quote
Really must get round to putting this page up properly:-
http://www.alfa-pages.co.uk/carbjet.htm
List of the jetting info I have dug out from workshop manuals for the flat 4 engined cars.
