baiones Alfa Sprint
Posted: Sun May 09, 2004 11:39 am Post subject: What plug is this ? |
Can anyone tell me what plug is this ?
It's not from the fog lights, i´ve check that...
Just cant find anything to plug it in...
 _________________ Carpe diem!!
Baiones
ALFA ROMEO 33 1.5 QV
ALFA ROMEO 33 1.7 QV
ALFA ROMEO 33 s16 QV
ALFA ROMEO Sprint 1.3
ALFA ROMEO 156 SW "Train Edition" ( it's a JTD... ) |
paddy granger Alfa Sprint
Posted: Sun May 09, 2004 2:56 pm Post subject: |
You are right, its not a fog light plug, thats the black one to the right of it
Not sure what plug that is. Do all of the lights work? |
baiones Alfa Sprint
Posted: Sun May 09, 2004 9:45 pm Post subject: |
| paddy granger wrote: |
Yes, they all work...
Everything works BTW... _________________ Carpe diem!!
Baiones
Piston Punisher sussex uk Guest
Posted: Sun May 09, 2004 10:13 pm Post subject: plug |
hi amigo,
I think it looks like the brake pad wear warning connection that goes to the alfa control warning panel inside the car,but its been years since i had a 1.7 8v. |
Posted: Mon May 10, 2004 7:20 am Post subject: |
That plug is floating loose in my engine bay too.
There are two wires going to my brake calipers on each side; I'm assuming when the brake pads are worn, the deadly brake danger light in the cluster between speedo and tacho will come on.
My car doesn't have Alfa Control, headlight washers, air conditioning or Gold Cloverleaf gauges, so maybe the plug is for one of those...  |
Ravi - not logged in Guest
Posted: Tue May 11, 2004 3:13 am Post subject: |
Bloody Alfa electrics. That brake warning light is the bane of my existence. Ever since I got my 33, which was and still is mint, I have tried to find out why that damn light keeps flashing - not quite rhythmic, but flashing all the time.
I've checked all the wiring, connections and still can't find the problem!! Clearly, I have also changed the pads and brake fluid to no effect. I'm thinking of just pulling out the bulb!
Later
R |
Marcin Alfa Sprint
Posted: Tue May 11, 2004 7:38 am Post subject: |
About the brake warning light: mine used to come on when the reservoir wasn't filled to the max. During acceleration/cornering/braking the sender thought there's no fluid in the reservoir and caused the light to go on. Filling the fluid to max level solved it.
Just a thought.
Marcin |
Posted: Tue May 11, 2004 8:38 am Post subject: |
| Quote: |
That brake warning light is the bane of my existence. ....that damn light keeps flashing - not quite rhythmic, but flashing all the time.
...I'm thinking of just pulling out the bulb! |
I thought there must have been a reason my warning light had no bulb in when I got the car!  |
Posted: Tue May 11, 2004 10:28 am Post subject: |
Mine also was lighting for some days when I discovered that the pad's cable had gone off its position and was touching the rim
It nearly cut it - I then wrapped it with insulating tape till I replaced the pads.
baiones Alfa Sprint
Posted: Thu May 13, 2004 8:16 pm Post subject: |
Thank you Guys!
It's probaby the alfa control pad light, that's why it seems no to be pluged for a long time!!  _________________ Carpe diem!!
Baiones
Matt Stolton Alfa Sprint
Posted: Fri May 14, 2004 1:45 am Post subject: It's not brakes... |
I'm certain my brake sensor leads dont make it into the engine bay.
On both my P4 and 1.7'ti', the cables from the brake pads follow the struts up and into the electrical bulkhead, and not into the engine area.
If you have an S2 car it may be for a second windscreen washer pump, as the Ti had headlamp washers, operated by a second pump. If you haven't got the Ti, the chances are the loom is standard across the range, and the options are bolted on as required to meet the badge on the car.
To test, turn headlights on, and activate the windscreen washers. 12V across the pins (assuming the relays in place) would indicate it is headlamp washers. _________________ Regards
John Hansen Alfasud
Joined: 05 May 2003 Posts: 62 Location: Queensland, Australia
Posted: Tue May 18, 2004 11:17 am Post subject: Wires |
On my '87 QV, the brake pad wiores enter from each fender and not from the fron of the engine bay. Is it possible that these wires are for a headlight wiper? _________________ John H
'87 Alfa 33 QV |
baiones Alfa Sprint
Posted: Wed May 19, 2004 8:41 pm Post subject: re |
Hi!
Front light washers ? hum..
Didnt know the 33 had those...
Thanks guys!! _________________ Carpe diem!!
Baiones
