philk Guest
Posted: Mon May 24, 2004 4:14 am Post subject: Water reservoir for wipers |
There is a leak in my water reservoir for front wipers. I've been under the car and iI can't seem to find where the the leak is. Where is the reservoir located? |
ady_botos Alfa Arna
Joined: 11 Oct 2003 Posts: 10 Location: Timisoara, Romania
Posted: Mon May 24, 2004 7:14 am Post subject: |
The water reservoir is located on the right side, behind the headlight, but under that plastic protection. To get to the reservoir, u have to remove that plastic.
I really think that your rubber hoses are the ones to blame. check them out as well. good luck |
Patrick Alfa Arna
Posted: Thu Jun 10, 2004 10:34 am Post subject: |
Before actually changing the reservoir check all hoses and the pumps. In my case the pump fpr the headlight washers was leaking!
Patrick |
