chipping- yes or no
phil
PostPosted: Mon May 31, 2004 5:23 am    Post subject: chipping- yes or no Reply with quote
I'm thinking about buying a chip for my series 3. Is it worth it and what are the down sides to chipping a car?
alfaqv33
PostPosted: Mon May 31, 2004 11:20 am    Post subject: Reply with quote
only chipping the car don't make the car faster. You feel al little more power between the 3500tpm and 4500tpm and you can make more tpm.
Look for squadra chip's, it's the cheapest good chip you can find for a 33
James Granger
PostPosted: Wed Jun 02, 2004 6:51 pm    Post subject: Reply with quote
Also, the Series 3 chip is soldered in place. You may need to be careful when replacing it!
alfaqv33
PostPosted: Wed Jun 02, 2004 7:44 pm    Post subject: Reply with quote
not all the series 3 are soldered, only the newest 93 and 94 are soldered.
But check it first!
paddy granger
PostPosted: Fri Jun 04, 2004 3:40 pm    Post subject: Reply with quote
But check it first!
I think that the 1351 cc IAW Marelli / Weber cars are the only ones which have soldered chips. The other models with Bosch injection systems have plug-in chips.
Correct me if I am wrong Confused
Laki
PostPosted: Mon Sep 06, 2004 9:35 am    Post subject: Reply with quote
You are right.... Very Happy
Chiping and making biger air-flow does the effect...I am thniking of puting alfa 75 2.0TS CAPACITY MEASURER since is almost the same only puting in more air...I will try and let youknow the results
-- ALFA ROMEO 33 Q4 --
