alfistjen Alfasud
Posted: Mon Jul 05, 2004 5:04 pm Post subject: 1.7 IE engine block on 1.3 carbs... with LPG... |
Hi guys,
I have the intention to buy a 1.3 carbed series 3 with LPG in it. The cheapest way to drive supid km's I suppose without having to diesel...
But I have two 1.7 IE 8V blocks here and I was wondering if it is possible to switch those blocks. Suppose the mechanical fuelpump has to be put over, but what I was really wondering is can the 1.3 carbs cope with the more air a 1.7 sucks? And how do the carbs addapt to the IE block? In case of emergency I can get my hands on a set of 1.5 Ti carbs which probabley have less probs feeding the 1.7. And last but not least... How does a IE block react on carbs feeding it?
And how does a boxer cope with gassy fuel replacing the liquid type?
Regards!!
Paul D. |
Eddie W Alfa 33
Posted: Mon Jul 05, 2004 10:06 pm Post subject: |
I thought all the carbed S3's had 40 mm carbs anyway, and are choked down for the smaller capacities. Should be feasable to sort something.
lesthegringo Alfasud
Posted: Tue Jul 06, 2004 10:31 am Post subject: |
Yes, it will be ok, you just have to remember to re-tune (and possibly rejet) the carbs to make the most of the conversion
Les |
