GIUSEPPE Guest
Posted: Tue Oct 05, 2004 2:40 pm Post subject: ALFA 33 1.7IE 8V INJECTION |
Hi Guys
I seem to have a bit of an idle problem+was hoping someone could advise.When the car idles the reves drop below 700 rpm+gives off a little shudder until i accelerate a bit.
Some one said to me a while back it could be the throttle body wjich is dirty and would need cleaning.
I am unsure if this is right and was hoping you could tell me if it is a likely problem.
Many Thanks
Giuseppe |
Marcin Alfa Sprint
Posted: Wed Oct 06, 2004 7:09 am Post subject: |
I think that a dirty throttle body would manifest itself more on the acceleration rather than on the decelaration. In your case it could be the lambda sensor.
Marcin |
