Free wheeeling - Fuel Injected '88 1.7
John Hansen
PostPosted: Fri Nov 19, 2004 10:50 am    Post subject: Free wheeeling - Fuel Injected '88 1.7 Reply with quote
Don't know if this is usual, but when braking and once you get to about 20km/h th car seems to loose engine braking. Any ideas? Thanks
John H
'87 Alfa 33 QV
bobbber
PostPosted: Fri Nov 19, 2004 11:24 am    Post subject: Reply with quote
Mine's the same....
Either it's because you have a dodgey clutch, or you're just not used to the 'free' nature of the Alfa engine?
Fiat Bravo 165 Sport
Marcin
PostPosted: Fri Nov 19, 2004 2:05 pm    Post subject: Reply with quote
Isn't that obvious? If you are in gear with the engine running, and even you don't put your foot on the accelerator, you still will find yourself moving forward (or backward). At that point you have zero engine braking Laughing . Simply the closer to stationary rpm the less engine braking power.
Marcin
John Hansen
PostPosted: Fri Dec 17, 2004 12:27 pm    Post subject: Engine Braking Reply with quote
Thanks Guys!
I have a twin carb 33 that doesn't have the same symptoms -that is you don't get the feel that the car is free wheeling. Therefoe, it's either something peculiar to the fuel injected version or the clutch is stuffed. I don't think it's the latter as the clutch and brakes will stall the engine.
Anyone else have any ideas - such as vacumn hose or other fuel injection paraphanalia that may result in this behaviour (which is different to the carbed version)?
John H
'87 Alfa 33 QV
