33 road setup
LDA
PostPosted: Mon Dec 20, 2004 4:38 pm    Post subject: 33 road setup Reply with quote
hey all,
i'm trying to improve my very nice '92 33 perm 4 so that it drives as i'd like. i'm only going to be using it on the roads so i dont want this car to be too extreme to drive over the b roads round my way.
handling
*shocks. is there a brand/model of shock that best suits the 33 without turning it into a super stiff jumping jack?
*springs. the perm 4 is quite low at the front anyway so i'd rather not go much lower than stock height. but the rear is waaay up in the air. do rear lowering springs exist for the perm 4? and would lowering just the rear upset the balance of the car? any other surgestions welcome.
*anti roll bars, does it have one? can i fit a better one? are there any out there?
*steering. i have a few ideas for this. can someone supply me with drawings of the steering on a s3 33? maybe from a workshop manual?
*camber. are there any top mount kits for the 33 so i can play with the geometry a little more? if so where might i find some for sale?
brakes
i assume that larger discs, pads, callipers and master cylinder from other alfa's could be retrofitted to the 33. is there a well trodden route of parts to use?
i have just replaced my brake fluid with all new dot5.1 and is has helped a little. but the brakes are still shockingly bad for a car with 4 discs!
exhaust. how big is too big. i dont want to get an exhaust that will kill my torque but i would like to remove any noise compromises that alfa were forced to build into the system. are there any good off the shelf exhausts? and or manifolds? i do not have a CAT on my car.
gear shifting.
are there any quick shift kits for the 33? or is there a diy mod that could be done?
thanks in advance for your help people
Luke.
A good workman allways blames his sh*t tools.
gritsop
PostPosted: Mon Dec 20, 2004 4:49 pm    Post subject: Reply with quote
About the shocks; I have now fitted Sachs shocks all around before 2 months. These are produced by the same factory as Boges are and the feel is like when car was new.There won't be any deviation from the original setup.
Thanassis Gritsopoulos
johnboy
PostPosted: Mon Dec 20, 2004 9:06 pm    Post subject: Re: 33 road setup Reply with quote
handling
Hi luke
Shocks! go for koni,but set them softer.if you dont wont a hard ride. you can get a thicker anti roll bar aswell but ive forgoten the name,matt has one on his dead p4. as for exhausts all i can say is make it as straight as poss so the gases fly out the back.i made mine from other silencers.straighthrough ones. brakes i have tarox on the front not bad. hope this helps abit
p.s. did you get my photos i sent you?
regards john
WODA WE NEED? MORE POWER!!
1999 freestyle superjet
Alan
PostPosted: Tue Dec 21, 2004 1:37 pm    Post subject: Reply with quote
LDA,
Not sure about the P4 but I know you can fit 259mm diameter vented discs of the front of a 164 .... but then you need to make caliper mounting brackets to suit, and make sure your calipers are wide enough to go over the wider discs (depends if you had a vented set up originally). I've actually used Wilwood Dynalite calipers - they're very good performance, very good value.
Then you have to make sure it all fits inside the wheels - I've made it fit in 14inch rims, but it'll depend very much on the design of your rim.
LDA
PostPosted: Tue Dec 21, 2004 2:15 pm    Post subject: Reply with quote
i was looking at the hi spec calipers. i have a set of the 4 pots on my pulsar and they seem to stop that quite well. but i do have 310mm discs on it!
164 brakes eh? the perm 4 does have vented dics on the front so maybe the stock calipers would fit? then again 4 pots would really do the trick.
i have heard some good things about the wilwood setup from other pulsar drivers. if they can stop one of them then they can defo stop a 33.
ho hum. hope i can find some deals in the january sales Smile
L.
