16v combustion chamber
RBL
PostPosted: Fri Jan 14, 2005 11:03 am    Post subject: 16v combustion chamber Reply with quote
Does anyone know the standard combustion chamber volume(s) for a
1.7 16v
Rich
Alan
PostPosted: Fri Jan 14, 2005 11:56 am    Post subject: Reply with quote
How accurate do you need to know? I've got the info for a standard head, but with larger valves fitted - I can't imagine that the valve change will make too much difference to the actual volume. If this is of use, let me know and I'll dig out the numbers from my build records.
Alan
RBL
PostPosted: Fri Jan 14, 2005 3:33 pm    Post subject: Reply with quote
That would be great Alan, thanks. I'm sure those figures would be close enough.
Alan
PostPosted: Tue Jan 18, 2005 12:37 am    Post subject: Reply with quote
Hi again,
Sorry for taking a while to get back ... busy weekend decorating when I would rather be building my engine! So trying to get it done ASAP ....
Anyway, the figures I have for the combustion chamber volumes are that all 4 cylinders are between 31.2 and 31.7 cc.
Just out of interest, why are you asking ... doing some interesting calcs or modifications?
TTFN
Alan
RBL
PostPosted: Tue Jan 18, 2005 7:53 am    Post subject: Reply with quote
Thanks for the figures Alan. It's actually for a friend of mine, Guy, who's a member but can't post at the moment. I think he's planning a blown motor. My standard 1.7 8v is fine for me.
Hope the engine build is going well.
Thanks again, Rich
neo
PostPosted: Tue Jan 18, 2005 11:44 am    Post subject: Reply with quote
Alan wrote:
Hi again,
TTFN
Alan
That could be the right volume. I've done some calculation and the total volume inculding chamber, gasket (0.040') and the piston is 47.5 cc.
Spyderman
PostPosted: Sat Jan 22, 2005 4:30 pm    Post subject: Reply with quote
Thanks for posting for me Rich Smile Smile
Spoke to AH motorsports (who are about 3 miles from work for me) and the guy who runs it gave me 28.4cc as the volume in the head, and
11.5.cc as the volume in the deck/piston top.
Can't seem to find what the gasket thickness is but http://www.victorygaskets.com/AlfaRomeo.htm
seems to list a 1.7 8v gasket at 1.4mm thick
under 1.7 as 1.2mm thick
Are 1.7 8v head gaskets same as 1.7 16v?
Using the figures AH motorsports gave me and a say nominal compressed to 1.3mm gasket I come out with 10:1, which I believe is the quoted stock compression
Laki
PostPosted: Tue Jan 25, 2005 12:06 pm    Post subject: Reply with quote
it should be same the engine block is the same....
-- ALFA ROMEO 33 Q4 --
