Posted: Mon Mar 07, 2005 12:00 pm Post subject: Water/mayo on the oil cap ... |
Last days I have noticed tiny water drops in the oil filler cap. Then some little amount of mayo was added to the cap.
Took out the oil filler tube along with the hose that goes to the manifold sleeve and noticed small white deposit on the cells of the oil filler tube and the inside of the hose covered with white deposit.
I cleaned everything with petrol and since then nothing bad has appeared.
However yesterday night when returned home I saw these tiny drops again on the filler cap.
Any ideas? I don't want to imagine that I 'm heading for head gaskets...
Could it be the weather? It has been quite a few days that the weather is coldy and rainy ... In addition the car runs in total about 30-45 mins per days so water condensation in side the motor could be a good excuse...
Any help appreciated.
BILL Alfa Sprint
Posted: Mon Mar 07, 2005 12:14 pm Post subject: |
No need to be alarmed.That is if you dont have any loss of coolant. Its usual in winter to see mayo in the oil filler cup.Its only moisture becoase of the small amount of Km you drive every day.Drive a trip for more than 100Km and it will be OK.
Bill. |
Posted: Mon Mar 07, 2005 12:27 pm Post subject: |
Yes Bill, I don't have loss of coolant and I think you are right.
Just took a look a couple of minutes ago and the cap is clean.
Thanks. _________________ Thanassis Gritsopoulos
ak Guest
Posted: Mon Mar 07, 2005 1:33 pm Post subject: |
most of the time i had the problem was due to moisture as well..
however 2 times i had to change head gasket (was noticing fluid lost).
hope it is the moisture bill. |
Posted: Tue Mar 08, 2005 8:10 am Post subject: |
When I got a second hand motor put in my car, there was heaps of mayo in the oil filler tube. The motor must have been sitting for ages to cause this, because after I wiped the white stuff out it never came back. I put heaps of km on my 33 now so there's no chance of condensation. |
alfa-alex Alfa Arna
Joined: 24 Apr 2004 Posts: 24 Location: gloucester. uk
Posted: Tue Mar 08, 2005 7:57 pm Post subject: |
like the people above say as long as there is no loss of coolant from the expansion bottle its just moisture in the engine.....
i've had this on a few cars before best thing to do is wipe the mayo off and then get the motor warm and take it for a good thrash!
Like you need any more excuse to take your alfa for a thrash!!!!! _________________ fast cars, fast women, slow beers! |
Harri Alfa Arna
Posted: Wed Mar 16, 2005 5:14 pm Post subject: |
At these latitudes that breather and mayo thing is really a problem sometimes. If there is mayo in the breather and you go for a longer drive at highway speeds, the breather tube actually freezes and the car starts jerking severely and sometimes even stops running completely. Then after waiting for 10 min the breather melts thanks to engine heat and the journey can continue for about 10km before the jerking starts again. The fix is to clean the breather frequently, remove the mesh from inside the oil filler and keep the oil level below the max mark, perhaps around half way between min and max (no hard cornering allowed then though). I suppose this is only in a very cold climate like the Finnish winter and won't affect you guys.
Harri _________________ 1990 33 16V QV
1993 164 QV 24V
1989 164 3.0 V6
2003 156 JTS Selespeed SW |
