High idle speed
nzoliver
PostPosted: Mon May 09, 2005 10:14 pm    Post subject: High idle speed Reply with quote
Razz Hi all,
My '91 1.7 33 8v is idling at 1200-1500rpm when warm. Any ideas? Got a suspicion the battery may be on its way out as this affects a lot of cars such as anything with Bosch Jetronic like Audis and Benzs.
I've a few of these now but still I come back for more!! This time it's a '91 1.7IE.
tvatavuk
PostPosted: Tue May 10, 2005 9:58 am    Post subject: Reply with quote
It can also be thermostat that can't close fully, or temp sensor...
Tino Vatavuk
bobbber
PostPosted: Tue May 10, 2005 10:12 am    Post subject: Reply with quote
What about the cold start throttle bypass system marked as 2 on the diagram :
The idea of this system is to allow extra air into the intake manifold when the engine is cold. If the valve stays open when the car is warm, this will lead to higher idle.
Warm the engine up, and then squeeze the pipe to see if this effects idle - if it does the electrical connection to the valve may be faulty or it could be the valve itself.
Rob
Fiat Bravo 165 Sport
bobbber
Sorry! Bad link!
ak863
PostPosted: Wed May 11, 2005 9:53 am    Post subject: Reply with quote
there is a way of decreasing the idle speed..
bobbber
PostPosted: Wed May 11, 2005 10:53 am    Post subject: Reply with quote
Certainly is....
At the front of the intake manifold there are two rubber pipes. The fat one is from the 'Cold Start Throttle bypass' (see previous post).
The thin one is to adjust the idle speed - you will need two spanners - warm the engine then adjust.
Rob
nzoliver
PostPosted: Wed May 11, 2005 9:02 pm    Post subject: Reply with quote
Cool Thanks all. Will look at it today maybe. I wish I had pictures like that to service it meself. Anyone help?
