Matthe_W_allace Alfasud
Posted: Wed Dec 07, 2005 12:53 am Post subject: Twin headlamp conversion for a 33? |
Seeing the thread below I like the look of these.
Wanted for a 1993 model though.
Where can I find a set? Or wud I need them made custom?
Cheers guys
Hope you are all well! |
Bellamachinna Alfa 33
Posted: Fri Dec 09, 2005 1:07 am Post subject: |
The double headlamp conversion, exists for the series 1/2(1983??-1989 cars), although is very dificult to get the parts, to do the conversion...
For the series 3, i never saw any conversion made...
So probably, you will have to custom build it yourself...
Posted: Fri Dec 09, 2005 10:53 am Post subject: |
Bellamachinna wrote: |
P.Camilo |
For a series 3 you will need a new bonnet, front bumper and grill. Series 2 parts will fit your series 3 but a lot more work than series 1 or 2... |
Posted: Fri Dec 09, 2005 11:50 am Post subject: |
Thanks for the help guys. Gonna see if I can make something myself, using the vacuum former at uni to get a shape based on the standard headlight, then maybe get the headlamps for the sprint. and shape the form to accommodate these and then go from there!
Great christmas project!
Does anyone know where I can find information regulations re headlight alignment for mot, as my makeshift will not have an adjustment in it.
Cheers. |
Posted: Fri Dec 09, 2005 12:29 pm Post subject: |
You could make something up for the headlight alignment adjustment I'm sure!!!!
Rear of light on the right, on the left is the profile.
Attach headless bolts onto the rear of the headlight housing. Make a cross shaped peice of metal, which the headlight is attached to. At the ends of the cross you can drill holes (a bit larger than the bolts) to allow the cross (with the headlight attached) to sit on the bolts.
Then a nut each side of the cross, on the bolts to allow you to align the headlamp!!!!
Whatcha think!?
Posted: Mon Dec 12, 2005 11:13 am Post subject: |
Don't you like my design???? _________________ Fiat Bravo 165 Sport |
Posted: Mon Dec 12, 2005 11:51 am Post subject: |
The Quad lamps on the minari kit (33 based) i built with my Father (10 years ago now!!) use a similar idea to yours Bobber.
From memory i think each of the 4 corners of each outer lamp has a stud attached. These studs pass thru individual brackets with nuts/ locknuts allllowing the lamp to be turned in and out and up and down.
Posted: Mon Dec 12, 2005 4:11 pm Post subject: |
There was Hella quad lamp desing for 33, and there are Citroens with quad (GS,CX,BX) and quad+2 lamps (XM) if you wanna try and salvage some from scrap yards. _________________ Tino Vatavuk
Posted: Tue Dec 13, 2005 11:36 am Post subject: |
Thanks for your help and ideas!
CHeers for the effort on the diagrams bobber!
That looks like quite an easy way of doing it. Salvaging some old citroen quads might be a good starting point too!
I really dont have time to start this project yet tho! Maybe during the summer when I get a bit more spare time (in the daylight!!!)
I will definately get pics up if I manage to succeed, and will also keep the mould should anyone else be interested in trying the same!
Matt |
Jorik Alfasud
Posted: Tue Dec 13, 2005 11:14 pm Post subject: |
Hi Matt,
I know of 2 sets of quad lights for the type 2 for sale in Holland, one is new and the other one was used on a series 3 33. The new set is EUR 200 and the used one is cheaper, don't know the price.
I could sent you the contact details of the sellers if you're interested? _________________ Cheers,
Jorik
1988 33 1.7 16v QV
http://home.planet.nl/~koper193/index.html |
Posted: Thu Dec 15, 2005 12:15 am Post subject: |
Jorik you star!
Yes please, that would be of great help. Could you pm me them please!
Would save me alot of hassle and time!!!
Who is selling these and do you know if they are DIY made or mass produced?
Thanks again
Matt |
Jorik Alfasud
Posted: Thu Dec 15, 2005 11:42 pm Post subject: |
Matthew,
you have PB, the lights will look something like this on a series 3:
This still needs some work but looks different and agressive, remember you have to alter, front bumper and grill. _________________ Cheers,
Jorik
1988 33 1.7 16v QV
Posted: Fri Dec 16, 2005 1:00 am Post subject: |
hmm, altering the front bumper and grille was not my intention though. I think I might have to set myself the challenge.
Will keep the contacts in mind and will decide by the end of the week what to do.
Thanks again everyone for your help! |
