She Thosen't Stop
Alfa 33 1.7 16v
PostPosted: Sat May 17, 2003 11:12 pm    Post subject: She Thosen't Stop Reply with quote
I Know that Alfa 33 have a " Little " problem with the breaks
My Question is will 164 caliper + disk fit to 33 with 15 inch wheel ?
Thanx
Viva La Italia
PostPosted: Sun May 18, 2003 9:40 pm    Post subject: Reply with quote
Dont think they will fit. Last time I checked I think 155 V6 disks will fit, but then you will need a spacer to move the calipers out. They are 280mm ish disks rather than the standard 239. They also have the same mounting bolt PCD as the 33, and virtually the same disk offset
Alfa 33 1.7 16v
PostPosted: Mon May 19, 2003 12:42 am    Post subject: Reply with quote
The problem is that we dont have 155 V6 in our country........... Crying or Very sad
Viva La Italia
PostPosted: Mon May 19, 2003 10:13 am    Post subject: Reply with quote
I have been told that Lancia Delta Integrale disks are virtually the same as the 155 V6, but never checked. Might be worth investigating
Ketil-no
PostPosted: Wed May 21, 2003 8:32 am    Post subject: Reply with quote
You can also try discs from a AR 145 2 liter. Maybe they fit.
They have atleast 4x98 bolt pattern and the diameter is 285mm.
Ketil
