Dreamracers Alfa Sprint
Posted: Thu Feb 09, 2006 11:21 pm Post subject: Disabling the rev limiter |
We have a Nomex rev limiter and want to run a higher rev limit (cam & valves sorted to cope with this)
How do I disable the rev limiter that is built into the rotor arm? OR are there rotor arms that dont have the rev limiter built in? _________________ (00=\°/=00) (00=\°/=00)
Alfasud 1.7Ti & Alfasud 1.3Ti
Posted: Fri Feb 10, 2006 8:23 am Post subject: |
On series2 33 you could just shorten spring. You could also buy rotor arms without limiter that was intended for some other cars like ie FIAT. _________________ Tino Vatavuk
Posted: Sat Feb 11, 2006 12:51 am Post subject: |
thank you. that is so obvious |
