re carbs on 16v
Goto page 1, 2  Next
greencloverleaf pat
PostPosted: Fri Feb 10, 2006 10:46 am    Post subject: re carbs on 16v Reply with quote
has anyone got inlet manifolds for a 16v engine so that carbs will fit on them.
Bellamachinna
PostPosted: Fri Feb 10, 2006 3:59 pm    Post subject: Reply with quote
Hi...
There`s not a "bolt on" manifold that you can use...
You have to get hold of 2 intake manifolds from a 16v, and 2 from a 8v carb version....
Have to cut them in half, and weld the bottom part from the 16v to the upper part from the 8v carb intake...
Hope this helps
P.Camilo
Rees Cees
PostPosted: Fri Feb 10, 2006 6:38 pm    Post subject: Reply with quote
Bellamachinna wrote:
Hi...
Hope this helps
P.Camilo
Mr. Green
greencloverleaf pat
PostPosted: Sat Feb 11, 2006 1:25 am    Post subject: inlet mainfolds Reply with quote
thanks Very Happy
Serpent33
PostPosted: Fri Feb 17, 2006 6:48 pm    Post subject: Reply with quote
Do you mean cut the throttle body off the 16V?
Bellamachinna
PostPosted: Sat Feb 18, 2006 12:24 am    Post subject: Reply with quote
Hi...
No... Not the throttle body...
I mean the intakes under the throttle body...
You need to make a hibrid intake if you want to install the carbs on a 16v engine...
Hope it helps
P.Camilo
Serpent33
PostPosted: Sat Feb 18, 2006 4:33 am    Post subject: Reply with quote
I'm curious. So how is the power delivery? As compared to 16V ie. Anyone knows? I actually fabricated the linkage but has not embarked on the project.
Rees Cees
PostPosted: Sat Feb 18, 2006 7:44 am    Post subject: Reply with quote
about 153 HBP and 200nM Torc for an normal street 16v
about 180 HBP for an Race engine
I have built both
PostPosted: Sat Feb 18, 2006 11:59 am    Post subject: Reply with quote
So you get ard 20 bhp just from carbs?
Bellamachinna
PostPosted: Sat Feb 18, 2006 11:22 pm    Post subject: Reply with quote
On my previous series 2 1.5 TI, that i converted to 1.7 16v with carbs, i didn´t notice.
(because i didnt had driven any 16v, with injection at the time)
Now that i own a series 3 16v, i can say that on lower rpm, the carbed version was faster, and more rev happy...
Not much change on top rpm (lack of fuel supply cappacitty by the carburettors ?????)
The series 2 was also lighter, which helped a lot...
The sound was also better... lots of backfires on the overrun...
P.Camilo
greencloverleaf pat
PostPosted: Sat Feb 25, 2006 9:54 pm    Post subject: 16v Reply with quote
thanks for the info i have had a 16v 33 and a p4 so will be interesting to see how it comperes when completed.
Rees Cees
PostPosted: Sat Feb 25, 2006 10:00 pm    Post subject: Reply with quote
something like this
Serpent33
PostPosted: Sun Feb 26, 2006 11:20 am    Post subject: Reply with quote
This looks high. Any clearance issue?
Serpent33
PostPosted: Wed Mar 01, 2006 8:17 am    Post subject: Reply with quote
P.Camilo[/quote]
Hi there. May I ask which distributor coupled your 16V carb conversion?
Bellamachinna
PostPosted: Wed Mar 01, 2006 2:17 pm    Post subject: Reply with quote
I used the 1.7 QV distributtor (series 2)...
Serpent33
PostPosted: Wed Mar 01, 2006 7:04 pm    Post subject: Reply with quote
I'm working on a 16V carb too. So which fuel pump you're using? I'm using carter. And my intended main jet, 160 with enlarged venturis. Since it's a modification, sure will benefit from you guys' experience. btw, gonna start a thread on final drive.
Frits
PostPosted: Thu Mar 02, 2006 9:54 pm    Post subject: Reply with quote
It is built in low...
Rees Cees is famous in the Netherlands... so here is a part of its site with pictures
Two type II 33 1.3s SW www.meisenbacher.nl/auto.html
baiones
Hi...
Hope it helps
P.Camilo
NO, NO!!
There's nothing under the throttle bodys.
You have to cut a throttle body, use the down half, and join it to the other piece.
Wink
Carpe diem!!
Baiones
ALFA ROMEO 33 1.5 QV
ALFA ROMEO 33 1.7 QV
ALFA ROMEO 33 s16 QV
ALFA ROMEO Sprint 1.3
ALFA ROMEO 156 SW "Train Edition" ( it's a JTD... )
KitCarLasse
PostPosted: Mon Mar 06, 2006 6:59 pm    Post subject: CNC bolt on 16v / karb manifols for sale Reply with quote
Hi im a guy from Denmark wich builds kitcar's on the VW type 1 chassis and uses Alfa Romeo boxer engines....the adapters for the vw transaxel to fit the alfa boxer is a part we ourself produce.....
Last year building my kitcar we ran into a problem - all racers used them but had never been produced in series prof... Intake manifol's for the 1,7 16v engine to adapt weber / dellorto 40mm karburators !!!!!!
I have seen many pour intake manifols wich we could call homemade
So my buddy Rolf and I desided to manifactor aset of super smooth super flow manifols - bolt on easy - made in one piece alu......
The price for a set of two manifol's are 3300 DK kr or about 472 euro !
Get more info write to me : kitcarlasse@yahoo.dk or +45 23 310 310
3D picture from the cnc-machine is possible to mail to you !
KitCarLasse
PostPosted: Mon Mar 06, 2006 7:13 pm    Post subject: Picturelink+More info of CNC manifol for 16v / karb adaption Reply with quote
More info... our manifol is lower than them you kan make off old throttlebodys + lighter weight..... + much better flow and no blind ends from old injectors Shocked
SO YES THERE IS A BOLT ON MANIFOL FOR KARB/16V SOLUTION
Link to danish website with picture from our CNC machine :
http://vwnettet.dk/modules.php?name=Forums&file=viewtopic&t=16041&highlight=16v
As you can see on the picture is our manifol superlow, the vacum fitting are build into the socket, the optional hole for brake vacum + sensors are ready for fit if you need them, finally the cooling water comes through an stainless steel pipe fitted into the alu manifol with 40 tons off weight !
This IS serious Wink
Plastic is fantastic
KitCarLasse
+45 23 310 310
1 sæt special fremstillet manifols til 2 stk dobbelte 40mm weber / DellOrto'er til brug for Alfa 16v boxer motoren der ellers kun er lavet med sprøjt !!! Dette giver ca min. 160-163 hk...
1 sæt pol alu ubrugt manifols bolt on - 3300 kr
Rigtigt fint til feks en buggy / kitcar sammen med en Alfa Adapter
1 adapter sæt komplet bolt on 5000 kr
: 26.07 KB
: Billedet er set 146 gange
Sidst rette af kitcarlasse den Ons Mar 09, 2005 5:03 am, rettet 1 gang
Rees Cees
PostPosted: Mon Mar 06, 2006 7:16 pm    Post subject: Re: CNC bolt on 16v / karb manifols for sale Reply with quote
wow that´s a lot of money. my were also proff made and they cost me:
2 intakes off an 16v. some hours flowing and 30 euro for welding.
My engine with 40mm dell orto´s is a pro engine and gives more than 180 Hbp
Rees Cees
PostPosted: Mon Mar 06, 2006 7:17 pm    Post subject: Re: More info of CNC manifol for 16v / karb adaption Reply with quote
How to put in a picture off our proud work ???
KitCarLasse
+45 23 310 310
lower means less torc! and the mixture off air and petrol is warmer.
KitCarLasse
PostPosted: Mon Mar 06, 2006 7:29 pm    Post subject: Reply with quote
The low manifol is made like this to fit under any hood.... however the all can be fitted with a spacer to make the hight that you want.... We further can offer an special made set for you to fit a 36mm karb og maybe a 48mm ? If you order a set just tell how higt you want the intake manifol from the engine surface and up to the karburator surface.... your wich is my comand Shocked Remember this is NOT an glue together part - THIS is made especially for you in one piece solid alu........ Very Happy
Rees Cees
PostPosted: Mon Mar 06, 2006 7:51 pm    Post subject: Reply with quote
Sorry i am not intersted in buing one of your intakes mine are working fine an fit alsow under the hood of my plastic 33 Wink
Why are you using alfa boxers in a kitcar? Subarau boxers are better, have standard more power and are better built (sorry alfa frends)
PostPosted: Mon Mar 06, 2006 8:39 pm    Post subject: Reply with quote
Cause off the pour conditions we have here in Demark regards building cars ourself.... the Alfa boxer is the only one wich are OK by the carinspection to get on the street..... Crying or Very sad
We soon will make an adapter for mounting bigger brakes at a 33.... anybody interested ?
Plastic is fantastic...... my kitcar weights total 620 kg and runs with a 33 1,7 16v engine fittede with two 40mm DellOrto karbs.... the tires are 205/50/15 and rear 345/35/15.... lightweight and good grip Wink
kitcarlasse
Goto page 1, 2  Next
Page 1 of 2
