Gearbox differences...
Bellamachinna
PostPosted: Mon Apr 10, 2006 4:09 pm    Post subject: Gearbox differences... Reply with quote
Hi all Very Happy
This topic, has already been covered, but i cant find it...
My gearbox, started to give up on me, and i cant find a good one from a scrapper...
My car is a 16v. I already considered a gearbox from a 145/6 1.7 16v, but the supports are completly different.
My question is this:
The gearbox ratios are the same between 1.7 and 1.5??
I also remember, someone saying that the gearbox from the 16v, has a "special" hole for the RPM sensor from the Motronic...
Is this correct??
If this is correct, does the gearbox from the 1.5 IE, features that "hole"???
Also, if that is correct, the gearboxes, from carbureted cars, cant be used on injection models.
Is this correct??
Thanks in advance
for yor help
P.Camilo
Bellamachinna
PostPosted: Thu Apr 13, 2006 11:39 pm    Post subject: Reply with quote
Anyone?????????????
bobbber
PostPosted: Fri Apr 14, 2006 7:53 am    Post subject: Reply with quote
According to the Alfa documentation - the 1.5, 1.7 and 1.7 16v gearboxes are the same part numbers.
Bob
Fiat Bravo 165 Sport
PostPosted: Fri Apr 14, 2006 9:56 am    Post subject: Reply with quote
The gearboxes are fairly similar, though somebody once said there were extra strengthening fins on the 16v one??? The overall gearing on the 1.5 definitely seems shorter than on the 1.7.
Ian M
PostPosted: Sat Apr 15, 2006 1:28 pm    Post subject: Reply with quote
According to the table on this site (4th icon from left at top) all the series 3 gearbox ratios are the same apart from the 1.3 which has a slightly shorter diff.
Presntly own
Red Abarth 500c
Bellamachinna
PostPosted: Sat Apr 15, 2006 2:16 pm    Post subject: Reply with quote
Hi again... Very Happy
Yes, i`ve already, been there... But my doubt, still remains...
The "best" gearbox that i found cames from a carbbed 1.5 (series3)...
I say "best" because i am taking the onwer word for it ( its a good friend thats living at 350 Km from me).
But i`ve heard that, in order to fit the 16v engine the gearbox case MUST have a place, were to insert the RPM sensor...
Carbbed cars, didn`t have this sensor, and i was told to get a 16v gearbox only (as i dont intend to swap gearbox internals).
I never saw a 1.5 gearbox, out of the car... But did the 1.5 IE also had a RPM Sensor???
Also, i dont want to travel 350 km, just to find out that the gearbox wont fit my car...
I compare this case, with engine block predisposition to mechanical fuel pump (carbbed cars) and blanked ones for injection models...
P.Camilo
Serpent33
PostPosted: Mon Apr 17, 2006 6:57 pm    Post subject: Reply with quote
To my knowledge, All 33's uses the same sensor. My 84 S1(carbed) and 91 S3 are the same and interchangable. The geared spedos were found in suds. Though I remembered the housing or linkange varies slightly, can't remember what exactly but does not interfere with swapping.
Bellamachinna
PostPosted: Tue Apr 18, 2006 12:52 pm    Post subject: Reply with quote
Thanks for your input... Very Happy
But i wasnt talking about speedo sensors.... Those are placed on the right hand side of the gearbox...
I was refering the RPM sensor, on the left side of the gearbox, that connects to the Motronic... Wink
Ian M
PostPosted: Tue Apr 18, 2006 9:14 pm    Post subject: Reply with quote
Try the link below to a previous thread which may help
http://www.alfa-pages.co.uk/viewtopic.php?p=8733&highlight=#8733
Presntly own
Red Abarth 500c
neo
PostPosted: Wed Apr 19, 2006 4:01 pm    Post subject: gearbox Reply with quote
Hi!
I had a 1.3 engine and I've replaced it with 1.7 16V. I'm using the gearbox from the 1.3 engine, and it has that hole needed for the pick-up for the injection. The car is 3rd series.
The only difference between the gearboxes is the shorter diff on the 1.3 engine gearbox so the car won't go over 190 - 200 km/h.
If you find a good gearbox from the earlier version, the hole on the gearbox casing can be easily drilled.
Best regards,
Nenad
http://www.quartermile.ws/forum/viewthread.php?tid=889&page=1
