P4 suspension bushes
graeme
PostPosted: Fri Jun 09, 2006 7:59 pm    Post subject: P4 suspension bushes Reply with quote
Does anyone know of a source of suspension bushes for a P4? I need the eight for the four rear tie bars. Alfa can't supply anymore and neither Superflex or Powerflex list them.
16v p4 In pieces.
tvatavuk
PostPosted: Fri Jun 09, 2006 8:24 pm    Post subject: Reply with quote
Aren't rear tie bushes same size on P4 as they are on 16v?
Power/Super should have them. Try seearching for item by dimensions not by asking for P4.
p.s. italian noname "who knos what quality" bushes should be still available.
p.s.2 Someone here once said that setting up much harder bushes on rear tie rods leads to cracks on point where bar is welded to bush casing.
Though I don't know how much harder bushes?
Tino Vatavuk
graeme
PostPosted: Fri Jun 09, 2006 8:45 pm    Post subject: P4 suspension bushes Reply with quote
Thanks for the reply.
The bushes are not the same. I have the Alfa parts CD and if you compare the 2 WD & 4WD, the part numbers for the bushes are different. One tie bar on each side has 40 mm bushes, the other 45 mm. Superflex & Powerflex just list eight identical bushes for the four bars. I emailed Superflex who said they are aware of the car but will not be producing the bushes as the numbers are too small.
Where can I search by diameter?
16v p4 In pieces.
stedee
PostPosted: Sat Jun 10, 2006 12:16 pm    Post subject: Reply with quote
hi
i have got the antiroll bars for the back of of a p4
i dont know how good the bushes are though,they are not perished that is all i can tell you
steve
brum brum
