Steering noise.....
bobbber
PostPosted: Fri Jun 30, 2006 2:32 pm    Post subject: Steering noise..... Reply with quote
All,
Just developed a new 33 gremlin! When turning the steering wheel (car running or not, and steering either way) the steering is making a 'knock knock knock' noise.
When the steering is stopped - the noise isn't heard, only when moving it.
Any ideas?
It doesn't sound like anywhere around the wheels - kinda like from behind where the steering column goes through the firewall into the engine bay.
Bob
Fiat Bravo 165 Sport
PostPosted: Fri Jun 30, 2006 3:18 pm    Post subject: Reply with quote
Yep.....mine has that too Evil or Very Mad
If you look behind the AFM there's a joint.....smoke it you'll feel better!
Sorry, there is a joint between column and rack, and it's here my noise comes from, yours too probably. I greased mine last year for a quick fix which was fine but now it's back! I'm going to investigate further.
bobbber
PostPosted: Fri Jun 30, 2006 4:13 pm    Post subject: Reply with quote
Lee, Sounds like a plan Laughing
Serious side though.... gonna take the whole lot off tomorrow and look into it. Interesting about the joint behind the AFM... that's EXACTLY where the sound is coming from.
Steering wheel -> column -> universal joint (for steering height) -> through the bulkhead -> then SOMEWHERE around here.
Thanks for the reply.
Bob
evanbottcher
PostPosted: Fri Jun 30, 2006 11:47 pm    Post subject: Reply with quote
This might be a strut bearing. When the strut bearing has gone dry and siezed up then turning the wheel will apply a rotating force to the spring itself, which I think must then slip around in the spring pan making a knock knock knock sound. This happened to me a while ago in the Sud and I thought it was the rack. You can feel the knock very firmly through the steering wheel.
Another symptom of this problem is that after turning a sharp left the spring is wound to the left and so the car will pull to the left for a bit. The opposite if you turn a sharp right.
I think you should be able to tell by looking at the spring itself while someone turns the wheel and see if it is moving.
hope this helps,
Evan.
http://www.trofeoalfasud.com
'77 Alfasud Ti
'69 1750 GTV
markgp4
PostPosted: Sat Jul 01, 2006 10:09 am    Post subject: Reply with quote
i have that knock too im pretty sure its the pan bearing as in my rush to get car ready i did not replace one i knew was dead...
make it go faster Smile
Ben_nz
PostPosted: Mon Jul 03, 2006 10:33 am    Post subject: Reply with quote
While we're talking about steering noises, my car makes loud snapping noises from the steering column each time the indicator self-cancellers pass the indicator stalk as you rotate the steering wheel. Passengers ask me if something is broken!
Something is always broken, of course, but I suspect that it's not the indicator self-cancellers - they're just meant to be that loud. Wink
