![](images/avatars/16346281664cd926e1097f1.jpg)
Posted: Thu Jul 06, 2006 9:22 am Post subject: Wheel Spacers |
When you put a wheel on your car, the wheel locates around the centre of the hub where the wheel nut is located, but if you use a wheel spacer you can no longer locate around the hub centre. Is there any way to solve this? Can you buy spacers which have there own locating lip for the wheel? Anyone had any experience of this? _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
serpent 33 Guest
Posted: Thu Jul 06, 2006 4:12 pm Post subject: |
If can't locate center, I gather the thickness is around 10mm? or more? I had built in bolt spacers at 15mm. You can customise the centre bore, and even the pcd. Good luck. |
ns Alfa Arna
Joined: 20 Apr 2004 Posts: 18 Location: the Netherlands
Posted: Thu Jul 06, 2006 8:30 pm Post subject: Re: Wheel Spacers |
I used 15mm spacers for rear wheels of my AR33. There are two type of spacers, ones are ready to use and are made for the type of car, other ones are universal and fit any car but to locate wheel properly on them you need to buy additional cups which are made for the type of car and have the same diameter as the hubs.
NS. |
Posted: Sun Jul 09, 2006 10:09 am Post subject: |
So are you saying that you can buy proper spacers which have location for the wheel If so where can I get them from ![Question](images/smiles/icon_question.gif) _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
ns Alfa Arna
Posted: Sun Jul 09, 2006 7:14 pm Post subject: |
paulhide wrote: |
So are you saying that you can buy proper spacers which have location for the wheel If so where can I get them from ![Question](images/smiles/icon_question.gif) |
I bought in a shop of autostyle.nl in NL, but may be better to look at the next link
http://shop.alfisti.net/Tuning-Styling/Alfa-33/Suspensions:::1_5_56.html
if it will be not opened then go to
http://www.alfisti.net/
then to shop -> tuning & styling -> alfa33->suspensions, you are there.
NS. |
Posted: Sun Jul 09, 2006 8:06 pm Post subject: |
Right ns, yes that's what I'm after. Thanks. See what I can find round here first. ![Smile](images/smiles/icon_smile.gif) _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
Sprintervention Alfasud
Posted: Sun Sep 10, 2006 10:47 am Post subject: |
Cheers for that. However at the moment I have more pressing matters such as the fact that yesterday, at last, I took off the whole rear axle and have put the replacement axle underneath ready to put in place this week. So far quite easy. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
Eddie W. (not logged in) Guest
Posted: Mon Sep 11, 2006 11:31 am Post subject: |
ADMIN ADMIN ADMIN PLEASE HELP. This is Eddie W.After8months of watching my wife of 40 yrs die of cancer I decide to rejoin the world through my favourite chatroom and it refuses to acknowledge my my existence no matter what I try. I don't need this. Can you help? My email is willco7@ihug.co.nz
Regards Eddie |
Scott Sander Alfa 33
![](images/avatars/88734733242d8a855752f0.jpg)
Posted: Wed Sep 13, 2006 3:48 pm Post subject: |
Eddie,
I'm sorry to hear about your wife
Until you reset password You can allways post here as guest.
Regards, _________________ Tino Vatavuk
Eddie W (not logged in) Guest
Posted: Sat Sep 16, 2006 11:11 am Post subject: |
Thank you Tino. Eight months of sheer hell. Just starting to get my life back together.
I can't change my password because it won't accept my email for some reason. It's driving me nuts because I want to ask opinions onP4 versus S2. There's a P4 for sale here and they're quite rare in NZ. It's cheap enough but I don't know how good they are. How reliable and how much power boost the transmission will stand. Drove it briefly the other day and wasn't too impressed with the performance compared to my S2 inspite of the 16V. Maybe all that extra weight. Is it worth it ?
Regards Eddie W |
Posted: Sat Sep 16, 2006 1:44 pm Post subject: |
P4 is better in the wet and on poor surfaces. 0-60 time (if everything is in good working order with a good clutch is 8.1 seconds), but only because of quick initial pull away. P4s are definitely more trouble than series 2 and eat clutches. Put on 195s and they really do start to handle well as they can make use of drive on all four corners. The back end is heavier than on a normal series 3 and the whole car is I think about 100kg heavier (than a series 3) to throw round corners, though the drive out is better. I would imagine their 50-70 times etc are a little slower than the normal series 3. Some parts are also becoming rather hard if not impossible to find now. It is also harder to get the power out of the 16v engine as you really need to keep the revs up. So personally I can't choose between the 8v carbed 1.7 or the P4, so I have both and they both make me grin for different reasons. ![Twisted Evil](images/smiles/icon_twisted.gif) _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
Posted: Sat Sep 16, 2006 2:04 pm Post subject: |
Imagine normal series 3 16v, and now put 4x4 on top of that.
They really do feel a bit sluggish after fwd, there realy are more things that can go wrong, and that you just cant buy anwhere these days. (ie 2 rubber mounts that hold prop shaft/visco to chasis)
Everthing Paul mentioned is true. _________________ Tino Vatavuk
johnboy 16 Valve
![](http://i319.photobucket.com/albums/mm480/johnboygtv/DSC01514-1.jpg)
Posted: Sat Sep 16, 2006 4:24 pm Post subject: |
Hi Eddie W
sorry to hear of your loss.
if you want a great 33,put a 16v in your series 2.you then get the best of both worlds.series 2's are liter and the 16v is tops. thats the way i would go.
regards john p.s glad your back ![Wink](images/smiles/icon_wink.gif) _________________ WODA WE NEED? MORE POWER!!
1999 freestyle superjet |
Posted: Sat Sep 16, 2006 8:51 pm Post subject: |
Thanks guys for the sympathy and info.
I've long wanted to supercharge one of my 33s and I thought that the p4 would be able to apply the power better{ ie no torque steer} and the charger would up the torque significantly on the 16V. Also easier to blow through and intercool with the injection. Tha aim would be an easy 170-180hp. I think the P4 will become a collectors item in time.
For items like the rubber mounts, perhaps moulds could be made and done in urethane.
My S2 is already on 195/50/15s, has the front chassis braces (reto fitted}K&N and soon to have the Zender bodykit fitted { finally} and a refettle with solid lifter cams etc. Oh, and lowered about 30mm and a crossover manifold.
SCOTT, I changed my email some time ago from hotmail to ihug and I'm sure I updated my details at the time but the site doesn't seem to recognise my current email as valid for my username and consequently won't allow me to change my password. It also won't allow my current password which I have written down. Frustrating. Thats why I thoght that with Admin rights you or Keith might be able to verify and sort.
Regards Eddie W |
Posted: Sun Sep 17, 2006 12:57 pm Post subject: |
Eddie
I think that 170-180hp wouln't be a problem for 4x4 system in P4, providing that all rubbers mounts are in top condition.
Scott and me are only moderators, Keith is only admin here. _________________ Tino Vatavuk
Posted: Mon Sep 18, 2006 1:54 am Post subject: |
Thanks Tino, perhaps one of you could bring my problems to Kieths notice. I really would like to get it sorted.
Regards Eddie |
Posted: Sun Sep 24, 2006 1:53 pm Post subject: |
Eddie,
I'll send him a PM, bUt dont know when I'll have answer. _________________ Tino Vatavuk
