icky Alfasud
Joined: 20 Mar 2003 Posts: 70 Location: Lismore NSW Australia
Posted: Thu Jul 20, 2006 1:35 am Post subject: Auto Repair Manual Translations |
Manual: Rotate anticlockwise.
Translation: Clamp with visegrips then beat repeatedly with hammer counterclockwise.
Manual: This is a snug fit.
Translation: You will skin your knuckles!
Manual: This is a tight fit.
Translation: Not a hope in hell, bucko!
Manual: As described in Chapter 7...
Translation: That'll teach you not to read through before you start; now you are looking at scary photos of the inside of a gearbox...
Manual: Pry...
Translation: Hammer a screwdriver into...
Manual: Undo...
Translation: Go buy a BIG can of WD40...
Manual: Retain small spring...
Translation: "Jeez what was that, it nearly took my eye out!"
Manual: Press and rotate to remove bulb...
Translation: "OK - that's the glass part off, now use some good pliers to dig out the base...
Manual: Lightly...
Translation: Start off lightly and build up till the veins on your forehead are throbbing...
Manual: Routine maintenance...
Translation: If it isn't broken... it's about to be!
Manual: One spanner rating.
Translation: Your mother could do this... so how did you manage to botch it up?
Manual: Two spanner rating.
Translation: Now you may think that you can do this because two is a low, tiny, little number... but you also thought the wiring diagram was a map of the Tokyo underground.
Manual: Three spanner rating.
Translation: OK - but don't expect us to ride in it afterwards!
Manual: If not, you can fabricate your own special tool like this...
Translation: Hahahahahahahahahahahahahahahahahahahahahaha!
Manual: Compress...
Translation: Squeeze with all your might, jump up and down on, swear at, throw at the garage wall, then search in the dark corner of the garage for while muttering "Piece of Sh@t" repeatedly under your breath.
Manual: Inspect...
Translation: Squint at really hard and pretend you know what you are looking at, then declare in a loud knowing voice to your wife, "Yep, as I thought, it's broke!"
Manual: Carefully...
Translation: You are about to cut yourself.
Manual: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Manual: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Manual: Turning the engine will be easier with the spark pugs removed.
Translation: However, starting the engine afterwards will be much harder. Once that sinking pit of your stomach feeling has subsided, you can start to feel deeply ashamed as you gingerly refit the spark plugs.
Manual: Refitting is the reverse sequence to removal.
Translation: But you swear in different places.
Manual: Prise away plastic locating pegs...
Translation: Snap off...
Manual: Using a suitable drift...
Translation: The biggest nail in your tool box isn't a suitable drift!
Manual: Apply moderate heat...
Translation: Placing your mouth near it and huffing isn't moderate heat.
Manual: Index
Translation: List of all the things in the book except the thing you want to do! _________________ Specialization is For Insects
1988 33 1.5 S 8V |
Posted: Thu Jul 20, 2006 8:20 am Post subject: |
Yep, spot on! Rings many bells Just two nights ago driving home I could here a slight blow from the front manifold. Got under the car and felt where the blow was, slightly burning my hand. Just as I thought, just leaking a little from behind one of the gaskets. Okay just undo the nuts clean everything up, use a bit of paste and put it back together again - 20 min job - done it a few times before. Well not quite. Undid the first two exhaust-manifold-retaining-nuts no problem and the third bought out the whole stud where the nut had rusted to the stud, still no problem, thought the same was happening with the fourth until it sheared completely and I was left with about half a cm of stud protruding from the block. Oh what fun.  _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
