Blown 33
James Granger
PostPosted: Sun May 25, 2003 11:11 pm    Post subject: Blown 33 Reply with quote
Thinking of creating a 33 Compressore. Any suggestions in terms of performance/cost/availability?
Performance should be interesting coming from the 1.3 engine, which is really asking for such a mod!
My brother and I are currently trying to solve the air-inlet problem, which is simply in the way. This also goes for the water pump and alternator.
The extra pully on the crank could power the thing; were the Alfa engineer's trying to tempt this or what? Just how can we fit it in?
We will probably also need a 16V gearbox, OMP clutch, new pistons for decreased compression ratio and a remapped chip. Not to mention Integrale brakes (all round?).
We think that a compressor will be more suitable than a turbo in terms of flexiblity; more power lower down the rev-range.
Scott Sander
PostPosted: Sun May 25, 2003 11:31 pm    Post subject: Reply with quote
I think you will need to use a toothed belt that is a couple of centimetres wide. I suspect you would snap belts if you tried to use just a normal V belt or similar.
Scott Sander
http://www.sanderfamily.com
Mixsynth
PostPosted: Wed May 28, 2003 3:36 am    Post subject: Reply with quote
Just get a 16V engine - surely? Confused
Hugh B
'98 145 QV
16V conversion pics/videos - now updated with extra pictures and explanations
View user's profile Send private message Visit poster's website MSN Messenger
John Hansen
PostPosted: Wed May 28, 2003 1:41 pm    Post subject: Kompressor or Turbo Reply with quote
Wouldn't this be easier. See article at www.autoseed.com/cms/A_1117/arcticl.hmtl which talks about dropping a Subaru EJ20 turbos into an ALFA 33. This should give 200 horses and according to the article is reasonably easy due to the fact that the alfa like the subaru has a NS flat four engine and there was plenty of width to squeeze the subaru into.
John H
'87 Alfa 33 QV
John Hansen
PostPosted: Wed May 28, 2003 1:47 pm    Post subject: Kompressor II Reply with quote
A guy I worked with suggested Eaton superchargers as a good "pice of kit". Info can be obtained from http://www.capa.com.au/eaton.htm
John H
'87 Alfa 33 QV
James Granger
PostPosted: Wed May 28, 2003 6:02 pm    Post subject: Reply with quote
Thanks John and Hugh,
I have already considered a Subaru engine, but would rather fit it into another 33 as a testbed (ie. locate a written-off Subaru with decent engine and shoe-horn the unit it into a mechanically dud 33 P4)
A compressor mated to an (Alfa) boxer engine should make a fabulous noise and would also present an interesting engineering project.
I will first have to consider insurance and road-approval in the Netherlands.
I shall keep you posted on the project.
Best regards
James
alexj
PostPosted: Mon Jun 02, 2003 7:22 am    Post subject: Reply with quote
You might want to have a look at these.... a supercharged alfasud and supercharged Sprint:
http://home.t-online.de/home/Rauen/aspedy1e.html
http://www.allgoodtechnology.com/alfa/
PostPosted: Tue Jun 10, 2003 12:21 am    Post subject: Reply with quote
There used to be a supercharged sprint about 1 mile from my house. The supercharger lived on top of the engine in line with the crank. It used a single SU carb and sucked through that. Then had 4 outlets from the supercharger with one pipe going to each inlet. The belt to drive it was only around 2cm wide.
By the way the 16V and 1.3 gearboxes on the series 3 have the same gear ratios, just that the 1.3 has a lower diff ratio.
John Hansen
PostPosted: Tue Jul 08, 2003 1:24 pm    Post subject: The Kompressor Reply with quote
Hi James,
Any further action on this Question
John H
'87 Alfa 33 QV
