James Granger Alfa 33
Posted: Wed Jun 04, 2003 6:40 pm Post subject: |
Leigh,
For the 1.7 16v, the Fuel pump relais (s12b) should be under the bonnet, on the right hand side (for LHD cars at least), against the sill. I think this is opposite the windscreen washer fluid bottle. The relais should be alongside the injection relais with diode (s12a). The fuel pump relais is on the left (towards centre of car) of the injection relais.
Hope this helps |
