carbs for 33...i'm lost!
zp
PostPosted: Sun Mar 23, 2003 11:05 am    Post subject: carbs for 33...i'm lost! Reply with quote
hi everyone
the other day i was having a look at some tech data concerning the 33.
so for series 3, fitted carbs are :
- two weber or two dellorto 40 for 1.3 engine
- two weber or two dellorto 36 for 1.5 engine
for previous cars, carbs are :
- weber 32, solex 32, or two weber 36, or two dellorto 36 for 1.3 engine
- weber 32, solex 32, or two weber 36, or two dellorto 36 for 1.5 engine
- two weber 40 for 1.7 engine
well i thought that the carb number (ie 32, 36, 40) reflected the size of the carb. so i don't understand why the carb size is the reverse of the engine size on the series 3 (or perhaps my data are wrong?)
besides, what are typically the bests carbs ever for a 33, i heard a lot that weber are better than dellorto, is this true? and what is the most desirable model?
thanks everyone for your answers
zp
PostPosted: Sun Mar 23, 2003 11:43 am    Post subject: Reply with quote
Although the 33 series 3 1.5 is listed with carbs in the workshop manuals, I have never heard of one being sold. As such I suspect it was developed and then not put into production
My experience with the carbs is on earlier cars fitted with Dellortos and later cars with Webers, so this is biased a bit as they played with the jetting for emmisions reasons. However I prefer the Dellortos, with the later Webers giving a horrible jerky throttle
zp
PostPosted: Sun Mar 23, 2003 11:46 am    Post subject: carbs Reply with quote
Basically, as engine size increases, so too does the Weber / DellOrto size. For the 1.5, the 36 IDFs are specified. For the 1.7, it's 40IDF.
Webers tend to be easier to set up than DellOrtos - although those who stuff around with the latter will say the opposite! Essentially, they work in the same way, although DellOrtos tend to have a more complicated air mixing system. Best? Academic really. All things being equal, either will do, as long as they are properly set up and well tuned to match the engine. If you want to fiddle with either, change things one step at a time. For instance, don't change emulsion tubes and main jets at the same time.
PostPosted: Sun Mar 23, 2003 8:00 pm    Post subject: Reply with quote
By the way, forgot about this. Knocked it up ages ago. Page listing some of the jettings for the 33's
http://www.alfa-pages.co.uk/carbjet.htm
alfafan
PostPosted: Mon Mar 24, 2003 3:05 pm    Post subject: Carbs Reply with quote
"Although the 33 series 3 1.5 is listed with carbs in the workshop manuals, I have never heard of one being sold. As such I suspect it was developed and then not put into production "
This is not correct.
It depends on the different Markets.
Here in Portugal, you see "lots" of series 3 33 1.5 with carbs.
But after the beginning of 1993 the only version was the 1.5 IE (Catalitic).
I have a 1.5 V - My wife´s car - It´s Series 3 1.5 with Hidraulic Tapets, 40 mm Webers, sun roufe and AC.
Carlos Oliveira
PostPosted: Mon Mar 24, 2003 3:51 pm    Post subject: Reply with quote
Yey, another bit of info to add.
I had never heard of a series 3 fitted with carbs before now. For the UK all the series 3 cars were fitted with injectio, with the 1.5 dropped from sale for 1993 (the cat cars we got were the 1.7 8V and the 1.7 16V). I know Ireland (another rhd market) got 1.3 carbed series 3 cars
The question is where got the 1.7 with carbs, or the 1.2 (not sure if it is a typo in the manual fiche)
neo
PostPosted: Mon Mar 24, 2003 6:28 pm    Post subject: Reply with quote
Hi.
I also have a 33 (3rd series) 1.3 91' with factory fitted 2 IDF 40 carbs. The engine also has hydraulic tappets.
PostPosted: Mon Mar 24, 2003 6:57 pm    Post subject: Reply with quote
Think most of the cars went to hydraulic tappets around 1987. Not sure exactly when though
I have a lhd 1.3 from Belgium which is an early series 3 with carbs factory fitted. I also have the remains of a 1992 rhd 1.3 which again has factory fitted carbs
PostPosted: Tue Mar 25, 2003 12:54 am    Post subject: Reply with quote
According to my manual scans (October 1988 - probably the same pdf's that everybody else has), the carb types are:
305.87 1350 2xTwin Weber/Dellorto 40mm main venturi 28mm
305.88 1500 2xTwin Weber/Dellorto 40mm main venturi 30mm
305.50 1700 2xTwin Weber/Dellorto 40mm main venturi 32mm
The 32mm main venturi is the giveaway..... you wouldn't use a 32mm main venturi, unless it was a larger engine (than the 1500) or you were racing your 1200 and intended to rev to 8000rpm.
Engine types 305.85 and 305.86 (1200/1350) are listed with weber 32DIR (23/24mm main venturi). There is a typo here too, as the label says "diffuser", for the 1200 and 1350 cars, but it is clearly the main venturi(s) that is listed.
Lex
alexj
PostPosted: Tue Mar 25, 2003 1:10 am    Post subject: Reply with quote
Just to clarify the above post, the earlier 1350 and 1500 twin carb engines all used 2xWeber IDF/Dellorto DRLA 36mm carbs. My understanding is that all the 1500 engines had 30mm main venturi and 1350 engines had 28mm main venturi.
For determining the character of the engine, it's the main venturi, not the carb barrel/throttle size that matters most.
Lex
