baldy Alfasud
Posted: Thu May 10, 2007 1:31 pm Post subject: Complete at last 1.7 16v carb sprint |
MY Alfa Sprint 1.7 16v project has come to an end finally!!!! and was well worth the effort . the car drives and handles great, torqe steer is much improved by using the multivalve engine because it has less torqe than the 8v at the bottom end but when above 3000 it comes alive in a big way .the car is producing 148 bhp on the dyno and it certanly feels and sounds like it . standard 1.78v carbs are fitted, and the standard air box and carb linkages have to be shortened by approx 25mm ,this setup still allows the intake of cold air to the carbs. Ignition is controlled by an ecu(MEGA JOLT) the wasted spark. you need a small throttle position switch on one carb(ford fiesta 1.1), and a 36-1 toothed wheel for the crank sensor mounted to the front pulley and a coil pack and leads from the ford kak sorry ka,and also an edis4 controller (fiesta 1.1)the ignition system excluding laptop cost less than a new distributor!! and can be mapped exactly to match your mods or future mods. and is easy to fit.
if you take yor time.
I hope this info will be helpfull to people ,ive tested it and it works well,very well. |
![](images/avatars/176194924442149ea4d4013.jpg)
stedee Alfa 33
![](images/avatars/1715825484680e86f55b62.jpg)
Posted: Thu May 10, 2007 5:27 pm Post subject: |
wow that sounds too technical for me , how did you find out all that stuff?
and well done - any pix _________________ brum brum |
hugh jinjin Alfasud
Posted: Fri May 11, 2007 6:25 pm Post subject: |
Let's see it then!!
We want some pics |
Posted: Fri May 11, 2007 7:40 pm Post subject: |
Overwhelming democratic vote for piccies methinks!
Posted: Fri May 11, 2007 8:26 pm Post subject: |
Thanks Lee,
Here are the pictures :
johnboy 16 Valve
![](http://i319.photobucket.com/albums/mm480/johnboygtv/DSC01514-1.jpg)
Posted: Sat May 12, 2007 11:17 am Post subject: |
Hi Lee
I want it very cool.good job chap
1999 freestyle superjet |
mt Alfa Sprint
Posted: Wed May 16, 2007 11:22 am Post subject: |
Impressive! Really like the idea of carbs on a 16v, just imagine it would drink fuel. Is this the case? |
baldy Alfasud
Posted: Wed May 16, 2007 1:43 pm Post subject: fuel consumpsion? |
Its actually pretty good, ive not had an alfa since i sold my p4. But from memory its about the same.But faster by a fair bit due to less weight. |
![](images/avatars/19060450664b72e2a31a610.gif)
Posted: Thu May 17, 2007 3:53 pm Post subject: |
I want it too!!
That open door pic has just sent many fond memories of my Sprint flooding back. Sold it in 1994- regretted it the moment the buyer pulled off the drive.
baldy Alfasud
Posted: Wed Jul 11, 2007 9:55 am Post subject: |
Thanks for the complements, will anyone be going to the sheffield alfa day as there hoping for a record turn out of suds/sprints/33s. should be a good day as long as its dried out from all the flooding!! Lee |
