Toad Alfasud
Posted: Fri Aug 17, 2007 4:37 pm Post subject: 16v running badly at startup |
Well I dusted off my old computer and got my favourites sorted,
remembered my old password and hey presto here I am... Long time since I've been here.
Anyhows I'm currently driving a 146 16v and on startup it runs like a pig sounds like it's on 3 cylinders until it warms up, which is taking some time because it's thermostat is stuck open.
Any ideas ? _________________ Shift for Brains |
Posted: Fri Aug 17, 2007 5:22 pm Post subject: |
Okay pull off leads by distributor with insulated pliers and see which one makes no difference, so you know which cylinder is not firing then check lead, plug, blown head gasket etc. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
Posted: Sat Aug 18, 2007 12:46 pm Post subject: |
If it runs smoother when warmed up, could be temp sender to ecu at fault.
If its using lots of fuel, possibly the lambda probe (oxygen sensor).
Toad Alfasud
Posted: Mon Aug 20, 2007 2:31 pm Post subject: |
Thanks for the feedback
Where is the temp sender ? and does that feed the temp gauge ? _________________ Shift for Brains |
Posted: Mon Aug 20, 2007 3:00 pm Post subject: |
The temperature sender for the ECU and for the dash are separate and different. There is also ANOTHER for the temp warning light.
Someone better than me with the 16 valve will tell you where it is.
Posted: Mon Aug 20, 2007 4:10 pm Post subject: |
Think the ecu temp sender is near the nsf throttle body, kinda on the inside, opposite the injector if you know what i mean.
Toad Alfasud
Posted: Tue Aug 21, 2007 9:10 am Post subject: |
Thanks Guys I'll have a look at my spare engien and swap parts over. _________________ Shift for Brains |
