removing rev limit on a 1.5 sud???....
knighty
PostPosted: Fri Aug 31, 2007 11:34 am    Post subject: removing rev limit on a 1.5 sud???.... Reply with quote
how do I remove the rev limit form my twin carb 1.5 sud engine?......someone has told me they think its in the distributor rotor arm, aparrently there is a spring/weight that opens up with the centrifugal force?........I havent actually looked yet.......how high should I safely rev the engine to once its removed?.......I'm thinking about 7,500 to 8,000.......its a bog standard motor with a foam ITG panel filter.
PostPosted: Fri Aug 31, 2007 7:17 pm    Post subject: Reply with quote
yup that is how its governed, you can get a different rotor arm with a limit of 7200. Check the torque / power curve as i think the max is achieved at a level below that limit. Someone else should be able to say where that is.
PostPosted: Fri Aug 31, 2007 11:32 pm    Post subject: Reply with quote
The rotor arm has the rev limiter. It is a pretty common rotor arm used on different cars, often with different rev limits (eg, Escort XR3i one fits, think the limit with that is 6300rpm).
To remove it just buy a rotor arm without the limiter in it. Cheaper. Just make sure you never need the rev limiter (know someone who blew an engine racing as the drive shaft popped out on full thorttle, revs went through the roof and blew the engine before they managed to back off).
PostPosted: Sun Sep 02, 2007 3:25 pm    Post subject: Reply with quote
After missing a gear once, over revving and bending a couple of valves, I put a rev limiter on, better safe that sorry.
suds
PostPosted: Mon Sep 03, 2007 12:54 pm    Post subject: no your limits Reply with quote
all the power and torque are over at 6200 i would leave the limiter in
romance of rust
alfasud 1.5 ti
alfasud super 1.3
Alfa 155 2.0ltr 8v
Fiat croma 1.9jtd
