Which ones are the timing marks on 16V
Alfalfa
PostPosted: Tue Sep 25, 2007 2:56 pm    Post subject: Which ones are the timing marks on 16V Reply with quote
There are two kinds of marks on the cambelt pulleys, a pair of T:s (or more like triangles) and then two lines on the upper pulley and one in the lower. According to the factory manual at no 1 TDC there's a T at the flywheel aligned with the dial and at that the I of the lower should be between the II:s of the upper pulley. However, the last check on the manual says to align the T of the flywheel and picture shows the small T:s at the pulleys aligned. So which one is correct? I think the timing marks are: T at the flywheel and II and I aligned and this is how I have them.
BUT! The engine does not run smoothly. It seems to be entirely out of breath. I have cleaned the heads, reground the valves to their seats, changed the air cleaner, cat and the lambda probe (yes, it had difficulties passing the MOT), distributor rotor and head and spark plug wires. Next to go in is new set of the platinum plugs but I'm not very optimistic.
I have also a 1.7 8V which runs much better so something is wrong. Evil or Very Mad
bobbber
PostPosted: Tue Sep 25, 2007 3:14 pm    Post subject: Reply with quote
I think the 'T's on the camwheels should all face eachother (in pairs) when the T on the flywheel is visible and the rotor arm of the dizzy is pointing to cylinder 1.
The I's and II's should all line up together but nothing to do with the flywheel
Bob
Fiat Bravo 165 Sport
ZeNiTh-PbArM
PostPosted: Tue Sep 25, 2007 9:52 pm    Post subject: Reply with quote
AAARGH Shocked
no!!!
the T mark on the flywheel shall be visible through the hole (engine @ TDC)
on each cylinder bank camshaft pulley marks I and II shall be aligned in such a way that the I is between the two bars of the II
this is the correct position for timing.
after installing the belts rotate engine two full turns and rechack proper alignment.
then rotate engine until both T marks on camshaft pulleys face each other one on cylinder bank ; in this position, loosen the tensioners, allow the spring to tension the belt, then tighten tensioner
repeat tensioning procedure on other cylinder bank
zp
bobbber
PostPosted: Wed Sep 26, 2007 9:25 am    Post subject: Reply with quote
AGHHH!!!! NOOOOOO!!!! Shocked
IGNORE ME.... HAVING ONE OF THOSE WEEKS!
Merci Zenith!
Bob
Alan
PostPosted: Wed Sep 26, 2007 8:34 pm    Post subject: Reply with quote
T mark on flywheel must be in the center of the hole so that is aligned with a marker.
Camshaft pulleys have to be in this positions
If it's all aligned, then you turn the engine by hand so that the arrows on one pair of camshaft pulleys aligne. Now you have to see an arrow on the flywheel too.
Then you turn the engine some more to align the arrows on the other two pulleys, there must be an arrow mark on the flywheel again.
If it's all like that then it's OK Very Happy
Sorry for my english Embarassed
Alfalfa
PostPosted: Sun Sep 30, 2007 3:49 pm    Post subject: Reply with quote
Excellent! Thank you all for replies. I'm still wondering how this model is so difficult to maintain. Now I'm about to re-tighten the cylinder head bolts and I have removed the M6 bolts holding the camshaft covers but I can't get the bloody cover (right side) pass the rear exhaust cam support block. There simply is no room between the head and the chassis beam.
I think there is one more thing to try before I scrap the miserable excuse of a car - remove the front engine support screws and force the engine sideways to the left to give more room to the right side of the engine bay.
Any other run into this kind of problems?
bensally
PostPosted: Fri Jan 23, 2026 12:43 pm    Post subject: Reply with quote
Οι τεχνικές ευθυγράμμισης και η σωστή συντήρηση των συστημάτων είναι κρίσιμες για την ομαλή λειτουργία κάθε ψηφιακής πλατφόρμας στην Ελλάδα. Η ακρίβεια στη ρύθμιση των παραμέτρων εξασφαλίζει ότι η εμπειρία παραμένει σταθερή και χωρίς σφάλματα σε κάθε στάδιο. Η λήψη του spinmacho app προσφέρει μια άψογα συγχρονισμένη πλοήγηση, επιτρέποντας στους χρήστες να απολαμβάνουν όλες τις δυνατότητες της πλατφόρμας με κορυφαία ταχύτητα και απόλυτη αξιοπιστία.
MaxJohnson
PostPosted: Fri Jul 03, 2026 2:17 pm    Post subject: Reply with quote
I've been exactly where you are – if the flywheel T is lined up and the lower I sits between the upper II's, then technically you've set it right. But if it's running that rough, it's almost certainly off by a tooth somewhere – I had the same issue and it turned out the belt had stretched. Swapping to platinum plugs won't fix this if the timing itself is off. This guide breaks it all down really clearly: https://richy-fox.org.uk/ And if your 1.7 runs better, you're on the right track – just gotta find that one gremlin holding this engine back.
MaxJohnson
PostPosted: Mon Jul 27, 2026 3:07 pm    Post subject: Reply with quote
That sounds like a classic timing confusion — I've been there with the 16V pulleys, and it's easy to get caught between the T marks and the I/II alignment. From what you're describing, the flywheel T at TDC and the lower I between the upper II marks should be the correct setup, but if the engine is running that rough, it might be worth double-checking the belt tension and the distributor timing as well. If you're looking for more detailed timing guides or want to see how others have tackled similar issues, www.drslot.co.uk has some useful forum threads and step-by-step posts worth checking out. Hope you get it sorted soon.
mehraji001
PostPosted: Wed Aug 26, 2026 12:51 pm    Post subject: Choose a girl to make your day Reply with quote
Maturity brings expertise that younger companions often lack. An Escorts in Punjabi Bagh with experience knows exactly how to please difficult clients. They have encountered diverse preferences and learned adaptation skills. These women handle awkward situations with grace and professionalism. You can relax knowing they manage the encounter smoothly. Consider booking mature companions for sophisticated, stress-free experiences.
