Posted: Sat Jun 28, 2008 6:30 pm Post subject: starter motor again!! |
Hey guys, I’m getting the not starting problem again, tapping on the solenoid worked once but no more, wiggled the earth wires for the immobiliser, worked once.
I have already stripped the starter motor, checking the brushes and re lubricating the solenoid, but all looked ok, as in no cracks in the magnets.
The car has been stationary for 7 months, but started 1st time on demand, not anymore? Any ideas? _________________ x2 33 16v
Posted: Sat Jun 28, 2008 6:33 pm Post subject: |
Are the electrical contacts on tight, I have had this issue before when I only finger tightened the nut. _________________ PHAT 33 |
Posted: Sat Jun 28, 2008 6:44 pm Post subject: |
if you need a starter motor I think i have one in my shed , all yours for ......nowt . _________________ PHAT 33 |
Posted: Sat Jun 28, 2008 8:46 pm Post subject: |
Did you ever do the Scott Sander mod- running in a supply wire direct from the battery with a relay fed from the original solenoid wire?
This solved an intermittant starter I had years ago. It has never failed since.
Posted: Sun Jun 29, 2008 11:51 am Post subject: |
I never got around to it, as I thought I cured it last time, when I thought it was the alarm at fault. I can’t figure it out, I think it might be high resistance in the wires somewhere, causing not enough power to activate the solenoid. The first time this happened I removed the black exciter wire off the starter and connected a wire in its place and ran it to the positive battery terminal. To start the engine I would turn on the ignition and then get out of the car and touch the wire on the positive battery terminal.
I can’t remember the exact wiring for Scott Sanders mod but I assume that you use the exciter wire to trigger the wire I had in place with a relay.
I will go out and measure the voltage and resistance on the exciter wire later.
thanks _________________ x2 33 16v
Dr A. 33 1.5IE Alfa Sprint
Joined: 23 Jun 2005 Posts: 133 Location: Nicosia - Cyprus
Posted: Mon Jun 30, 2008 9:12 am Post subject: |
Hello,
I went through the same problem with you for over a year now. It occured occasionally, usually when I had to make a quick stop. But recently the car did not start at all.
If you have already tried to connect a wire from the battery straight to the starter motor and it started then it is not the motor at fault.
Better check the ignition module. It might need replacement (about 30 Euros for a used one) but also make sure thay the wiring that connects the ignition module with the main wiring loom (under the steering wheel) has all in place.
When you are having the problem just wiggle a bit the ignition wires. Maybe one of them is broken.
Best of luck _________________ 1994 Alfa 33 1.5 IE Cat. 220.000Kms and still going strong!!! (Από την Αθήνα και τώρα στην Λευκωσία) |
Posted: Mon Jun 30, 2008 11:03 am Post subject: |
Thanks for conformation that it’s definitely not the starter motor. I was and now am convinced that it is the alarm, which has an immobiliser. The wires out of the ignition module have, “I think from memory” an earth “yellow and some other colour wire” that is spliced, this is wired into the alarm and if I turn off the alarm and remove the block connector to it, join these 2 wires at the block connection the car starts, some times. Normally I just wiggle these wires when they are attached to the alarm and the alarm is on and connected, it usually starts.
Thanks for the tip, I will try.
Just to recap on how to measure voltage and resistance on my multimeter and not blow it up, is it as following?
To check the voltage on the black exciter wire, remove said wire, turn multimeter to 20 volts range, attach 1 probe to the wire and the other to earth, turn ignition key.
To check current, turn multimeter to Ohms, attach one probe to black exciter wire and the other to the terminal it should go to on the starter motor and turn ignition key. _________________ x2 33 16v
Posted: Tue Jul 01, 2008 1:22 pm Post subject: |
typical, i went out to the car with my multimeter and tried, several times to start the car throughout the day and it started 1st time every time, DOH! So i could not get a reading of when its not working. _________________ x2 33 16v
Posted: Wed Jul 02, 2008 9:34 am Post subject: |
Typical, when I needed it for work yesterday guess what? It didn’t start did I have my multimeter? No, did I have time? No It didn’t want to start several times, so I used a wire from the +battery to the exciter wire. I'm thinking of just getting a push here to start button and wire it into the dash with a fuse connected to dais exciter wire and a double pole spade connector on the starter motor. That way I can try the key and if it doesn’t work, push the button.
Still haven’t located the fault _________________ x2 33 16v
Posted: Wed Jul 02, 2008 10:39 am Post subject: |
I'd just do the mod. It's very straightforward, then problem solved and no hacking your dash to bits- although a start button might be cool.
You just need some suitable cable, relay (mine was an old spotlight one i had kicking about), a few conectors, and a fusable link near to the battery terminal.
Posted: Thu Jul 03, 2008 11:21 am Post subject: |
I was thinking of just using a wire with a 1/4" piggyback connector on one end. One end could be attached to the starter motors exciter wire and where the exciter wire goes, so I still have the choice of trying the key and not changing any of the original loom. The other end could go onto a push to make contact single pole switch and then from the other pole of the switch could be wired with another piggyback connector, onto the cigarette lighter, which is fused.
My problem is that this method is not like how a proper push to start switch would be wired in, as my wiring has a fault and is not reliable, there is no way of preventing the starter motor turning again if the button is pressed after the engine has fired up, apart from not pushing the button again. Can anyone think of an easy way to stop wondering hands from doing this? _________________ x2 33 16v
Posted: Thu Jul 03, 2008 11:32 am Post subject: |
BigAl wrote: |
Can anyone think of an easy way to stop wondering hands from doing this? |
Tie up your passengers, or make 'em sit in the back.
I'd still recommend the Sanders mod It's so neat and tidy. i might take some pics if you want.
Posted: Thu Jul 03, 2008 11:38 am Post subject: |
i dont think that would fix my problem because its this wire thats not getting enough juice, if any, to start the starter, i doubt it would be enough to trigger the relay??
I like the idea of a tied up passenger lol. This button needs to be clearly shown, no need in hiding it!!!
Unless i get one that says passenger ejector seat, press at your own risk _________________ x2 33 16v
Posted: Thu Jul 03, 2008 12:12 pm Post subject: |
BigAl wrote: |
My problem is that this method is not like how a proper push to start switch would be wired in, as my wiring has a fault and is not reliable, there is no way of preventing the starter motor turning again if the button is pressed after the engine has fired up, apart from not pushing the button again. Can anyone think of an easy way to stop wondering hands from doing this? |
Wire it through a relay triggered by the oil pressure warning light. Once there is oil pressure the light goes out and the relay disconnects power to the starter switch.
Posted: Thu Jul 03, 2008 6:03 pm Post subject: |
That sounds great, so to clarify, can I connect a 1/4" piggyback on the oil pressure switch instead of routing around the console to find the warning light. I assume the oil pressure switch just lights up the warning light. Is it an of off or could this be used to feed an oil pressure gauge and therefore be a variable output? _________________ x2 33 16v
dave Alfa Sprint
Posted: Thu Jul 03, 2008 6:09 pm Post subject: re multimeter |
hi al
ac volts ---------- mains voltage etc
dc volts -----------battery voltage ???
ohms ----------- resitance or you can check continuity
amps ------------- current
make sure you have on right setting and amps as you could blow your multimeter ??
good luck
dave
ps could be your immobilser had this proplem on one of my alfas and on a freinds fiat coupe _________________ alfadave1@btinternet.com
VW TOURAN 59 PLATE WHITE WITH TINTED WINDOWS AND ALLOYS MR BLING
CHEVY MATIZ |
Posted: Fri Jul 04, 2008 11:37 am Post subject: |
BigAl wrote: |
That sounds great, so to clarify, can I connect a 1/4" piggyback on the oil pressure switch instead of routing around the console to find the warning light. I assume the oil pressure switch just lights up the warning light. Is it an of off or could this be used to feed an oil pressure gauge and therefore be a variable output? |
Think the oil pressure switch just earths out the warning light. Not 100% sure but think if you put the relay in that wire (so the wire goes to the trigger +ve and then out again on the trigger -ve) it would work.
Personally I would get a few feet of cable and some spade connectors, and connect it to the existing wiring. Hopefully you could avoid chopping the wires at all.
Posted: Wed Jul 16, 2008 6:51 pm Post subject: |
Dr A. 33 1.5IE
Quote: |
Better check the ignition module. It might need replacement (about 30 Euros for a used one) but also make sure thay the wiring that connects the ignition module with the main wiring loom (under the steering wheel) has all in place. |
This is the cause, the immobiliser is wired here and it must be a dry joint. I can now start from inside the car. Something is not right as I’m getting sparks again like matt used to, fixed that by using a block connector as the insulation had melted and was shorting on the steering column. Not sure what’s causing it this time, needs further investigation.
Thanks very much. _________________ x2 33 16v
Posted: Sun Jul 27, 2008 2:39 pm Post subject: |
Car will not start at all from the key now, even after wiggling the ignition wire, i will have to remove the steering column cowling and investigate further. At the moment im having to start my car with wire from + battery terminal to exciter wire on the starter, not good when its dark _________________ x2 33 16v
Posted: Fri Jul 17, 2009 8:40 pm Post subject: |
I think I fixed the problem by removing the alarm to find out the shorting had melted the immobiliser part of the alarm, causing it to be immobilised all the time.
Nearly a year later the car has started to do it again, not the alarm this time, I fixed all the wire loom around the steering column, so not that, not the starter motor because I have found out what the problem is.
Anyone want to guess what it was/is as I haven’t got round to permanently fixing it yet? _________________ x2 33 16v
Posted: Fri Jul 17, 2009 9:42 pm Post subject: |
A bad connection in the ignition switch? _________________ 155 sportpack
Posted: Fri Jul 17, 2009 11:43 pm Post subject: |
Big Al,
If the ignition module is not at fault try the Sander's mod. It cost me 20 euros at a local car electrician and since then the car starts everytime. Somehow not enough juice gets from the battery to the starter motor (ageing wiring) and so this mod makes sure that enough power gets to the starter.
If you want to be sure that the starter motor does its job get a thick wire and connect the positive pole from the battery to the starter motor... if it starts then you just need the mod nothing else.
Good luck _________________ 1994 Alfa 33 1.5 IE Cat. 220.000Kms and still going strong!!! (Από την Αθήνα και τώρα στην Λευκωσία) |
