Matt Stolton Alfa Sprint
Posted: Thu Jul 31, 2003 1:04 pm Post subject: White Dials |
I vaguely remember, on the old discussion list, someone having a template/file for making your own dial kits for the 33. Has anyone still got the file?
I am after the file for a s3 33 (P4 if you have it but I can mod to suit) in MPH. I've got adobe photoshop at home so the file can be in any format that will work on that.
I presume you take the file to a helpful printers who will print it onto the appropiate plastic.
Please help if you can, as it would finish my cabin off a treat. _________________ Regards
andrew Alfa Arna
Dreamracers Alfa Sprint
Posted: Sun Aug 03, 2003 11:04 am Post subject: |
In the UK, it is illegal not to have MPH showing....
Anyone got a UK version? |
Adam H Alfasud
Posted: Sun Aug 03, 2003 1:51 pm Post subject: |
I've got a LHD UK registered 16v that has a MOT and only KMH on the speedo.
No one ever had a problem with my old escort that only had KMH on the speedo.
Maybe I only ever take my car to be MOTd at the 'right' place!
Adam H |
Posted: Mon Aug 04, 2003 8:38 am Post subject: |
Cheers for the URL, Iwill have a play and try and mod them to MPH, and try and do a P4 version as well. If I manage to suceed, I will repost the English(MPH) versions
Thanks Again _________________ Regards
Posted: Mon Aug 04, 2003 10:11 am Post subject: |
Nice one, thanks Matt! |
Posted: Mon Aug 04, 2003 4:55 pm Post subject: |
Don't say thanks too quickly, it taken me over 12 months to get my P4 project going, and I still haven't got bearings or heads back yet!!!! _________________ Regards
Posted: Sat Aug 09, 2003 9:08 pm Post subject: |
Adam H wrote: |
I've got a LHD UK registered 16v that has a MOT and only KMH on the speedo. |
Same for my 1.3 33, and same for several of my bikes. It is still technically illegal but I have never got any hassle over it
Slimboystew Alfa Arna
Posted: Tue Aug 12, 2003 11:40 am Post subject: MPH on dials |
Hi Matt,
I have a P4 and have a set of white dial templates with MPH, so if you want them drop me an email and I'll send them over.
Stewart _________________ 1991 33S P4 - the dogsbollox
1997 155 2.0 16V Sportspack. |
Paul Doc Alfa Arna
Joined: 16 Apr 2003 Posts: 22 Location: Glasgow,Scotland
Posted: Tue Sep 02, 2003 8:19 pm Post subject: |
Has anyone a link for white 1.5ie dials, in MPH? (Heads off, see what you mean about getting a torque wrench in there...) |
P4 Paul Alfa Sprint
Posted: Tue Sep 02, 2003 9:11 pm Post subject: white dials |
hey Stewart,any chance of sending me the white dial file for a p4 |
Posted: Fri Sep 05, 2003 8:31 am Post subject: Thanks for the responses... |
Thanks Stewart, I have emailed you. _________________ Regards
Toad Alfasud
Posted: Tue Sep 16, 2003 11:35 pm Post subject: |
I was just looking at the white dials file & i was just wondering what materials you use to print them up on & what are the steps on getting this done??
Thanks |
Graham Alfasud
Joined: 25 Nov 2003 Posts: 32 Location: Lismore, Brisbane Australia
Posted: Thu Jan 15, 2004 3:57 am Post subject: White Dials |
Does anybody on here know the kind of plastic that has to be used to replace the black dials? I have the template files and I have also replaced all the tacky green bulbs with Blue LEDS although i had to put in a voltage resistor for this as the bulbs get 12v and the LEDs pop if they get more than 4V(Range liked is around 3.5V) Any help would be greatly appreciated _________________ 5 Alfa 33's, 2 Suds God there is no help for me
Also own 2 Complete 16V Engines(Spare) And Have a Sud Rally Car in Production |
Posted: Thu Jan 15, 2004 9:28 am Post subject: |
Does anyone have the template file for a MPH white dial template. The links above no longer exist. Also what material would I ask the print shop to print them onto?
Cheers. |
Scott Sander Alfa 33
Posted: Thu Jan 15, 2004 10:15 pm Post subject: Re: White Dials |
Graham wrote: |
Does anybody on here know the kind of plastic that has to be used to replace the black dials? I have the template files and I have also replaced all the tacky green bulbs with Blue LEDS although i had to put in a voltage resistor for this as the bulbs get 12v and the LEDs pop if they get more than 4V(Range liked is around 3.5V) Any help would be greatly appreciated |
Graham,
You need to limit the current to the LED to around 20mA. So a 560 ohm resistor would be fine, you should not use LEDs by themselves. _________________ Scott Sander
http://www.sanderfamily.com |
Graham Alfasud
Posted: Thu Jan 15, 2004 11:04 pm Post subject: White Dials |
Thanks Scott,
I already have the correct resistors in with the LEDS else they would have blown by now and they work a treat ive also changed all the bulbs in all the switches(Power windows, rear wipers etc to be blue LEDS again using resisitors. My message in relation to this post however was about the correct material to use for the white face guages _________________ 5 Alfa 33's, 2 Suds God there is no help for me
lesthegringo Alfasud
Posted: Fri Jan 16, 2004 12:43 pm Post subject: Orangegrovevilla site |
Toad, just tried to go to the site you mentioned for the MPH dials, and I keep getting the no such site message - is it still up and running, or can you send the files to us?
Les |
Posted: Fri Jan 16, 2004 7:35 pm Post subject: |
Real shame those templates were only in kmh. Does anyone have the mph templates on their computer? Also when you take the needle off the speedo or rev counter (to put the white dials on) how do you know where to put them back on the mounting pin ? ie. How far round ? You might be doing 70mph and your speedo would only be saying 50 for instance. As to what material, guess you could just print out on card and then face the card with some of that sticky clear vinyl ? _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
