Posted: Fri Mar 06, 2009 4:38 pm Post subject: |
Keith, is there any reason why the part in brackets at the end of that address isnt included? I tried enclosing the whole address with URL but it didnt work _________________ x2 33 16v
Posted: Fri Mar 06, 2009 9:07 pm Post subject: |
Al Feredo DS 3000's or 2500 pads are best, they are a little expensive and have no sensors, also they produce alot more brake dust but if its better braking you want then these are the ones you want. _________________ PHAT 33 |
Posted: Fri Mar 06, 2009 10:14 pm Post subject: |
I wanted to get the 2500's in the past but never got round to it as they are expensive. I have opted for standard cheap new pads as i want to fit new pads to a new big brake conversion and if i were to buy them now it would mean putting used pads on new disks. _________________ x2 33 16v
jol Alfa Arna
Posted: Tue Mar 10, 2009 11:34 pm Post subject: |
I'm pretty convinced new discs, pads and brake fluid will do (for myself). But then I've already got the vented discs standard on my SportWagon.
Pagid RS4-4 (orange) is the improved Pagid blue
http://www.alfapower.nu/gallery/album1069/Pagid_rs44
http://www.alfapower.nu/gallery/album1069/bromsar_och_powerflex
Haven't tried them with any sticky rubber so I can't tell. But with the word from users of pagid on Alfa 75, they cost, but last (and brakes like their racecars should). _________________ Peter Strandberg
33 SW 1.7megasquirt 4x4 -89 |
Posted: Tue Mar 10, 2009 11:51 pm Post subject: |
go on, how much jol???
I find the standard oem set-up absolutely pants, brake fade big time and takes ages to come back, this was only after 2 - 3 hard fast stops.
I have tried a lot of different pad and disk combos in the past and found 40 or 60 grove red dot with race pads the best but i havent tried tarrox yet. I only got brake fade once and i was driving hard and it came back quickly. I tried mintex pads, not bad, never got round to trying the ds2500 though. I have given up and will go to big brake conversion, when i can. _________________ x2 33 16v
Rich B Alfa 33
Posted: Wed Mar 11, 2009 12:30 pm Post subject: |
I have use Tarox 40 groove discs front and rear with their strada (fast road) pads. They're really good but fade after prolonged use which I don't think you'll ever cure on standard set up as the discs are too small really. As Al says, the answer is a conversion, what are your plans Al? |
Posted: Wed Mar 11, 2009 5:26 pm Post subject: |
I would like to do what was suggested on this here site.
The standard disks off a 145/6 20L TS (i think) and the bracket made by some one, making use of the original 33 calliper and some hot race pads, like the DS 3000's or 2500. If no good then the same disks but 40 / 60 groove.
I have already got the space saver off a 145/6 in case of a flat and have 15" wheels, but not a 15" spare wheel, hence the space saver. _________________ x2 33 16v
Posted: Wed Mar 11, 2009 8:43 pm Post subject: |
A few years back I fitted Tarox Sport Japan crossdrilled and grooved disc's with the Ferodo DS 2500 pads, bled the system with some dot5 fluid and they were great for about a month. I then after a couple more years fitted Pagid disc's and pad's and again bled the system through and these were really crap . Anyway having fitted some 304mm disc's and twin pot race calipers and the support for the master cylinder, the pedal is almost as good as my 147. I do feel the 33's brakes could be better, but like the car's character the brakes are the same certainly what I call "progressive". The next thing to do would be to replace the master cylinder for a seperate clutch and brake system and I reckon this would sort the response we all would like. Oh and maybe fit some cold air ducting to reduce the fade. _________________ PHAT 33 |
jol Alfa Arna
Posted: Thu Mar 26, 2009 7:08 pm Post subject: |
BigAl wrote: |
Keith, is there any reason why the part in brackets at the end of that address isnt included? I tried enclosing the whole address with URL but it didnt work |
Not sure on that in particular, but the forum software tries to recognise thigns that could be a link and makes them links (rather than plain text). Sometimes with odd characters it screws up.
Sudmeister Alfasud
Posted: Tue Mar 31, 2009 12:59 am Post subject: |
Hi all,
I'm keen to sort my brakes out too but I'd like to keep the car looking fairly standard (ie original 14" wheels). Presumably this GTA brake conversion will need at least 16/17" wheels to fit over the disks?
Would I be mad to consider trying to mount a big brake conversion in-board? Does anyone know if this has been done?
Cheers _________________ Alfasud 105Ti Green Cloverleaf
33 16v |
Posted: Wed Apr 01, 2009 3:15 pm Post subject: |
I gave the brakes a testing last night and i think they are shot now. I got brake fade, however, i have had brake fade in the past and there was loads of heat coming from the disk. This time there was a feint smell but hardly any heat, could they just have glazed, could the brake fluid boiled even there seemed to be no heat, maybe the pads are absorbing all the heat? MY disks are a little thin, could this be a cause? The pedal is longer and now hard and brakes are pants _________________ x2 33 16v
Posted: Wed Apr 01, 2009 4:49 pm Post subject: |
That you have a solid pedal suggests it isn't water contamination of the brake fluid. I suspect the pads are shot, possibly with the disks contributing.
Posted: Sun Apr 05, 2009 4:08 am Post subject: |
How weird is this, it is back to how it was before after a day or so. I guess the pads glazed as there was hardly any heat when i got brake fade. _________________ x2 33 16v
Posted: Sun Apr 26, 2009 10:42 pm Post subject: |
The brakes have seemed ok but I didn’t push them. I replaced my disks today and will have to wait again for them to bed in on these disks.
I forgot to pump the pedal before I set off and scared myself when I came to stop _________________ x2 33 16v
Posted: Wed Apr 29, 2009 3:35 pm Post subject: |
I have replaced the disks and here are some pics of the old ones. I have had different views as to whether or not the should have been changed
Posted: Wed Apr 29, 2009 6:55 pm Post subject: |
Yeah they look foooooked (worn as i can see a prominent lip at the outside edge) funny colour as well, has the disk been in contact with copper grease or any tyre shine stuff?. _________________ PHAT 33 |
