baldy Alfasud
Posted: Fri Aug 21, 2009 6:02 pm Post subject: idf weber carb |
Hi, i have been cleaning one of my carbs and have lost an air bleed screw! its the one next to the mixture screw normally covered with lead circular plug. I was hoping that someone on here may have an old carb or the screw from one, that i could use,cheers lee |
Posted: Fri Aug 21, 2009 8:07 pm Post subject: |
Hi Baldy, there may be a supplier on flea-bay, a few months back i was cleaning my idle jets and must have dropped one, i replaced all 4 for about 7 quid, if you have no joy there try Southern carburettor's they normally have everything on their shelves and are really helpful. _________________ PHAT 33 |
Posted: Fri Aug 21, 2009 10:29 pm Post subject: |
Hi, which carb is it? i have quite a lot of spares for twin webber & Dellorto carbs. _________________ 155 sportpack
Posted: Sun Aug 23, 2009 4:38 pm Post subject: |
I have found the bit you need. Ill post it off to you monday. _________________ 155 sportpack
baldy Alfasud
Posted: Fri Aug 28, 2009 7:07 pm Post subject: |
Cheers Alex for the part its spot on, if only everything was this cheap/free.cheers again Lee |
Posted: Mon Aug 31, 2009 3:04 pm Post subject: |
porf Alfa Arna
Posted: Mon Sep 28, 2009 6:11 pm Post subject: |
Just another post to say a quick thanks to Alex who dug out the missing bits (cold start circuit spring, retaining guide and washer) for my 40 IDFs as well
Posted: Mon Sep 28, 2009 8:31 pm Post subject: |
Always happy to help guys. _________________ 155 sportpack
