Posted: Thu Jun 03, 2010 10:33 pm Post subject: Cylinder bore damage |
Hi all,
Last month i've stripped down a 1.3 engine with 140 000 kms on it. The engine was running satisfactorily before the teardown. Upon careful inspection of all the parts, I found a deep straight scratch in cylinder #1 cylinder bore, 3mm wide. Just like if some grit got trapped between the piston rings and scratched the bore all the way. It's not very deep but honing the bore will not be sufficient to make it disappear.
There is no apparent damage to the piston, the rings, or the rest of the engine. Maintenance seems to have been regularly performed, oil and coolant were clean, no bearing or tappet wear.
Ever seen such a disaster? Any ideas what might have caused it?
Posted: Thu Jun 03, 2010 11:43 pm Post subject: |
HI ZP,
Only thing I can think of is the motor being left unused for a long time. Oil had turned to solid and a piston ring was frozen hence the scratch on the bore.
Posted: Fri Jun 04, 2010 8:28 am Post subject: |
If any of piston rings were stuck long enough to scratch cylinder bore so much that could be seen on rings as big flat spot.
Maybe some dirt or debris from spark plug failure/change entered cylinder. _________________ Tino Vatavuk
RFlower Alfa 33
Posted: Fri Jun 04, 2010 10:43 am Post subject: |
Did you match up the scratch alignment with the piston you removed from that bore?
It would be unusual for the piston to be unmarked.
Is it posible it was caused by the gudgeon pin/piston pin? _________________ Dick Flower, Nr. Carcassonne. '94 Trofeo 1.4 ie (F), '93 Imola 1.3/1.4 ie (now for breaking) (F), '91 1.7 ie (GB)(spare car), '86 Sprint 1.5 QV (F). '87 VW Syncro camper (F), '73 NSU Ro80 (F), '99 Fiat Seicento (F) |
Posted: Sat Jun 05, 2010 10:55 am Post subject: |
Thanks for the replies, I carefully checked piston and rings and no apparent damage is visible. I tried to take photographs of the scratch but it's very difficult to take a proper picture due to all the light reflections inside the bore.
Since the scratch stops a few mm before the top of the cylinder, I would suspect the rings more than the pistons. Would it be possible that the sharp edge of the ring could cause the scratch?
RFlower Alfa 33
Posted: Sat Jun 05, 2010 11:42 am Post subject: |
I have seen such damage from broken rings, but the cause was obvious, I assume you have removed the rings to make sure they have no damage and no buildup of deposits behind them.
Last year I had a 3mm brass nut and spring washer (from the filter assembly) inside my boat's diesel engine. There was damage to the piston crowns and valves but none to the bores, although that could be just lucky.
Both items stayed in (different) cylinders for several revolutions before they went out of the exhaust. They were gone before I got the engine stopped, but left clear prints on the pistons, so are there any marks on the piston crowns?
Do you have any record of previous work? It could be possible the cylinder was damaged previously, and someone just replaced the rings as a cheap fix. If you can't find anything at all wrong, this would be my best guess. A lot can happen in 140,000 km. My Imola's camshafts and several tappets were destroyed after 130,000, for no obvious reason.
It may be that some small foreign body found its way into the cylinder, lodged above the top ring, and is now long gone.
Possibilities:
Engine was run with the filter removed.
Something dropped into the filter housing when the filter was being changed.
Something got inside auxiliary piping connected to the inlet - are any of the pipes broken or damaged?
Are there any hard carbon deposits on the valves which could have detatched and gone in? - this would only happen if the engine was burning oil or running very rich.
Have you examined the plugs closely?
I once had a plug insulator disintegrate due to overheating, I had temporarily fitted a regular plug instead of a high performance one. I suggest you look closely at the plugs and their insulators. _________________ Dick Flower, Nr. Carcassonne. '94 Trofeo 1.4 ie (F), '93 Imola 1.3/1.4 ie (now for breaking) (F), '91 1.7 ie (GB)(spare car), '86 Sprint 1.5 QV (F). '87 VW Syncro camper (F), '73 NSU Ro80 (F), '99 Fiat Seicento (F) |
