rjbevan Alfasud
Posted: Sat Aug 16, 2003 11:01 pm Post subject: Handbrake |
My Clan Clover failed it's MOT on the handbrake (it uses the complete Alfa Sud drive train but at the back). The off-side works OK but the near side was not working very well. The tester suggested I change the disks and put new pads in (as the nearside disk is slightly warped). So I rang my local brake supplier and they said there are 2 types listed for the Sud. Is that correct? If so how do I tell which one I should buy?
Also to get the car through the MOT (I have 14 days for a free re-take) I thought about just getting the handbrake to work so I can change the disks at my leisure. Since the handbarke cable works both calipers (and the nearside is at the end of the cable) should I adjust the inner pad on the nearside caliper to reduce the travel or is that a no-no? Otherwise how do I get both sides to work well? The Haynes workshop manual is not very helpful on this point!
All suggestions wellcome
Richard |
Gary UK Alfa Sprint
Posted: Sat Aug 16, 2003 11:49 pm Post subject: |
Don't mess around with the pad clarances as you are likely to have one wheel lock while the other still turns, the ideal situation to put you in a spin.
Brakes are a NO BODGE AREA as they keep you and more importantly other road users/pedestrians in one piece.
As for which type of disk to get, quote your chassis number as most suppliers have the range of numbers for the corresponding part. |
rjbevan Alfasud
Posted: Sun Aug 17, 2003 9:06 am Post subject: Handbrake |
Hi Gary, thanks for the advice.
Only one problem, my chassis number is 0002 and I have no chassis number to say which Sud my engine/transaxle came from. But looking at the Haynes manual I suppose the dealers may be quoting me for the inboard disks on the original Sud and for the outboard disks on the Sprint. Do you agree?
Richard |
Posted: Tue Aug 19, 2003 8:46 pm Post subject: |
There were 2 types of inboard disk. Early ones had (I think) a couple of tabs to attach the disks, later ones had 6 bolt holes. Given when the Clan Clover came out I would say it almost certainly has the later 6 bolt disks.
The handbrake only works on the inner pads I think. Make sure they are adjusted correctly
rjbevan Alfasud
Posted: Wed Aug 20, 2003 8:45 pm Post subject: Handbrake |
Thanks Keith, I've now had a look and the discs have four mounting holes. So I presume later ones have six. Although it's meant to be a production car, there is no guarantee with regard to the heritage of the gearbox! With not having a pit I've chickened out and will put the car into a garage to do the work (I need to get the MOT!).
Thanks again
Richard
PS How do I get the "Alfa Arna" under my name changed to "Clan Clover". I tried to include a picture of my car with my profile but it refused to take it. |
Gary UK Alfa Sprint
Posted: Thu Aug 21, 2003 12:10 am Post subject: |
The Alfa Arna is Kieth's form of punishment for being a newbie to the forum Your Sud/Sprint/Arna/33 derivative will change with the number of posts you post on the forum. You are not the first person to be alarmed by this just keep contributing to the forum and you will loose this unwanted handle. I myself am quite happy to be a Sprint smug bastard I know
I bet when you set them up Kieth you weren't expecting this amount of feedback te-he-he-he |
Posted: Thu Aug 21, 2003 11:19 pm Post subject: |
If I was really cruel I would have made the lowest ranks Lada or Nova (or if I was exceptionally cruel it would have been Audi........I don't like Audis having owned one).
It was just a bit of fun.
Posted: Thu Aug 21, 2003 11:22 pm Post subject: |
Changing the picture should be easy, but there is a limit on the size, both number of pixels and the actual size of the file.
It is easiest just to have a small image loaded up on some web space and then link to that.
