Posted: Sat Apr 27, 2013 11:58 pm Post subject: |
Thought I'd update this thread as its been a while.
List of things to do to finish Steevee Romeo
Fit front race shocks and race springs
Fit 1.5 sud gearbox
Fit K&N aif filters
Get Lightened flywheel
Get bucket seats and harnesses
Get oil cooler
Get roll cage
The race shocks I have have been filed to increase camber and are a bit bent up from race use. I would really love to use my camber adjusting sleeves I had made, which means butchering my standard shocks to accept the Koni inserts Anyong got a set of straight ser 3 shocks they don’t want, that I can hollow out to accept the Koni inserts and have machined for camber sleeves?
I will fit the gearbox at the same time as the flywheel.
I need to find out if P4P can remove 3kg from a standard 16v flywheel, if they can, it will save buying one fromTTV
Filters are universal blank ones and need to have 40mm holes drilled in them and mounts made.
Deciding on what seats to get, comfort/lightness, bit tricky, any suggestions?
Can anyone suggest what make and size of oil cooler to get _________________ x2 33 16v
Posted: Wed May 08, 2013 4:27 pm Post subject: |
Sud 1.5 box fitted
Lightened flywheel will be fitted soon, DOH!! lol
getting ser 3 struts machined to take my camber adjustable sleeves.
get some uprated streering arm bushes so I can use the ser 3 adjustable tracking arms on my ser 2 non PS rack _________________ x2 33 16v
Posted: Thu May 09, 2013 7:28 pm Post subject: |
You must sure love taking gearbox's off Al! |
Posted: Fri May 10, 2013 12:08 am Post subject: |
Well... I was going to do it but the ramp wasn't free early enough for me to do it in time before driving to work, so someone else did it.
I know I know, I am capable, just ran out of time.
So might get to do it when I change the flywheel. _________________ x2 33 16v
Posted: Wed May 21, 2014 1:44 am Post subject: |
Ok update.
Need to fit the following
Lexan windows
Roll cage
Bucket seats
Harnesses
Oil cooler
Coilover front suspension
Black series powerflex bushes
Cf bonnet
Fiberglass tailgate
Remove the following
Dash
Remaining sound deadening
Carpet
Headlining
Remaining plastic interior _________________ x2 33 16v
Posted: Sun Jul 20, 2014 4:16 pm Post subject: |
Finally fitted the class f front springs and race valved koni shocks, had the rears on for a while with koni sports shortened and made top adjustable, but not enough for the class f springs.
waiting for bucket seats. http://www.corbeau-seats.com/cs
advice needed for setup, I will start a new thread. _________________ x2 33 16v
