armoore33 Guest
Posted: Fri Jan 20, 2012 3:42 pm Post subject: Series 2 sportwagon. |
Hi all, I've had my 33 for 18 years now although it is sorned at the moment. I really must get round to sorting out the nearside rear wing; usual problem with filler cap surround rusting. I need to get a panel (hens' teeth) or get someone more skilled than I with sheet metal to deal with it. So if anyone can assist I'd be very grateful. The rest of it was in good condition when it was laid up. Leather interior plus loads done over the years (mostly by me) including complete engine rebuild when I managed to break the crankshaft. |
Posted: Fri Jan 20, 2012 6:12 pm Post subject: |
Thanks for that, I knew i'd seen it somewhere, but forgotten exactly where. |
deggy Alfa Arna
Posted: Fri Jan 20, 2012 6:37 pm Post subject: |
Hi mate, did mine about 6 months ago and it turned out great, but I ordered a panel from a German site and it turned out to be a series 2 panel with a steeper ridge at the top, so I had to cut it down as it didn't match the ridge on the series3. Just thought is give you a heads up so you don't have the same problem. |
armoore Alfa Arna
Joined: 20 Jan 2012 Posts: 13 Location: Croydon, Surrey.
Posted: Sat Jan 21, 2012 12:19 pm Post subject: |
Mine is series 2 so it looks as though the repair is viable, thanks. |
Posted: Sat Jan 21, 2012 6:50 pm Post subject: |
I thought the series 2 and 3 SWs were the same at the rear. _________________ Alfa33 QO 1984
Alfa33 1.3i.e. 1994 |
Posted: Sun Jan 22, 2012 7:03 pm Post subject: |
eagle3 wrote: |
I thought the series 2 and 3 SWs were the same at the rear. |
I agree. _________________ PHAT 33 |
