Radiator
Ian M
PostPosted: Sat Mar 30, 2013 5:07 pm    Post subject: Radiator Reply with quote
My radiator decided to spring a leak today.
I have a spare in my shed so will fit that.
Question
Before I start, is it an easy straightforward job or are there any pitfalls ?
Presntly own
Red Abarth 500c
The Wombat
PostPosted: Sat Mar 30, 2013 5:30 pm    Post subject: Reply with quote
From limited experience so far, the biggest issue is the amount of room. On my P4, the crank pulley comes very close to it.
Not sure if there is an easy way.
Drivers:
- Green Fiat 20VT Coupe
- Champagne 155 V6
- Winter Freelander
- Mrs Wombats Freelander
Projects:
- Various 33s
- Some 155s
Hibernating for 2015
- 75 3.0 Cloverleaf
- 155 Q4 Winny
- Red 33 16v
PostPosted: Sat Mar 30, 2013 6:56 pm    Post subject: Reply with quote
Ian,
Take the bonnet and grille off and it comes out dead easy with fan attached out the front of the car.
The Wombat
PostPosted: Sat Mar 30, 2013 7:02 pm    Post subject: Reply with quote
There you go, the easy way Very Happy Very Happy
Drivers:
- Champagne 155 V6
- Winter Freelander
Projects:
- Various 33s
- Some 155s
- 75 3.0 Cloverleaf
- 155 Q4 Winny
- Red 33 16v
Ian M
PostPosted: Sun Mar 31, 2013 1:01 pm    Post subject: Reply with quote
Well thats the easiest rad Ive ever changed.
And no it didnt involve removing the bonnet (it is easter after all) and grille.
Presntly own
Red Abarth 500c
PostPosted: Mon Apr 01, 2013 9:36 am    Post subject: Reply with quote
Woops Embarassed bit more room on an 8 valver
Ian M
PostPosted: Mon Apr 01, 2013 6:14 pm    Post subject: Reply with quote
Yep, disconnect the hoses, 2 screws on the fan, remove connections for temp sender, undo the bolt on top of the rad and it slides straight out.
Presntly own
Red Abarth 500c
Brit01
PostPosted: Mon Apr 01, 2013 11:00 pm    Post subject: Reply with quote
yep beauty of the 8valver. fun engine to work on.
all easy Very Happy
S2 33 1988 1.7 QV
