Linkage Bush
PostPosted: Sat Jun 22, 2013 6:17 pm    Post subject: Linkage Bush Reply with quote
Just done head gaskets, water pump and belts.
Anyone know where I can get hold of new rubber bushes for the gearbox end of the linkage Question (1988/9 cars)
(Both my series two 33s' gearsticks rattle a bit in 3rd or 5th gear and it's not gearstick end)[/b]
eagle3
PostPosted: Sun Jun 23, 2013 9:52 am    Post subject: Reply with quote
Saw one for sale in France http://www.leboncoin.fr/equipement_auto/359716021.htm?ca=5_s
You'll have to check it's a series 2 model. The one on my '94 33 is a bit shorter and fatter. That one may well be the right one.
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
PostPosted: Sun Jun 23, 2013 10:30 am    Post subject: Reply with quote
Paul,
Also:
http://www.alfaparts.co.uk/detail/alfa-33-s3-gear-lever-linkage-rubber-bush-77.htm
This is for s3 so not sure if ok for your s2, but the part number's the same as eagle's.
I'm selling this so if it's any good PM me mates special Wink
PostPosted: Sun Jun 23, 2013 10:31 am    Post subject: Reply with quote
Paul,
Also:
I'm selling this so if it's any good PM me for mates special Wink
Bobkelso
PostPosted: Sun Jun 23, 2013 5:06 pm    Post subject: Reply with quote
uhm..:
Alfa 33 88-89: code 60502642 ( length 38mm? ID 12mm ? OD ??)
Alfa 33 90-94: code 60524873 ( length 35mm? ID ?? OD 19mm?)
88-89 one is available on ebay and it seams it's the easier to find of the two Very Happy :
http://www.ebay.in/itm/ws/eBayISAPI.dll?ViewItem&item=170850415773
http://www.ebay.it/itm/ALFA-33-DAL-88-AL-90-BOCCOLA-LEVA-CAMBIO-28499-/170850415773
This one is from Pirelli (may be better rubber?)
http://www.ebay.it/itm/ALFA-33-DAL-88-AL-90-BOCCOLA-LEVA-CAMBIO-PIRELLI-DEPOCA-38167-/170855706778
Ps.: if you buy one, can you post exact measures?
(Lenght, Inner-Diameter, Out-Diameter ) ..
I'd like to know if it is adaptable also for S3 in case
the S3 version will became non available in the future..
PostPosted: Sun Jun 23, 2013 9:55 pm    Post subject: Reply with quote
Thanks Bobkelso, I've sent off for two and will measure them for you. They do look very similar to the S3 ones (thanks John and Eagle), but do have a different part number.
PostPosted: Tue Jul 02, 2013 2:12 pm    Post subject: Reply with quote
bush - code 60502642
length 38mm
ID 12mm
OD 19mm
So it would seem to be the same except 3mm longer.
Bobkelso
PostPosted: Tue Jul 02, 2013 8:59 pm    Post subject: Reply with quote
Ok thanks, Very Happy
yes it seams the 89-90 version
is only a little longer (+3mm)
than version 90-94..
Probably is adaptable.
eagle3
PostPosted: Wed Jul 03, 2013 9:09 pm    Post subject: Reply with quote
I have a spare new one for my '94 33. I'll have a look at it. Gritsop kindly got me two from Greece a few years back.
Not sure at the moment when the linkage was modified.
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
eagle3
PostPosted: Sat Jul 06, 2013 6:43 pm    Post subject: Reply with quote
Having compared the two side by side yes if you shave 1.5mm off each end you'd have a series 3 bush. Very Happy
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
