Cylinder 2 no compression!
Goto page 1, 2  Next
Brit01
PostPosted: Wed Sep 11, 2013 10:40 pm    Post subject: Cylinder 2 no compression! Reply with quote
Bad news!
Thought I had a fuel issue.
No compression on number two.
Mechanic will remove the head on Monday.
Very strange he said. We had almost 180psi last year.
No ticking noise either.
Burnt valve or broken ring?
Seat worn??
S2 33 1988 1.7 QV
eagle3
PostPosted: Thu Sep 12, 2013 7:37 am    Post subject: Reply with quote
I take it cylinder 1 is good.
Camshaft ok?
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
Brit01
PostPosted: Thu Sep 12, 2013 12:54 pm    Post subject: Reply with quote
1 is fine. Why?
Cams are new. No ticking nioses from tappets either.
Burnt valve possibly or damaged seat.
S2 33 1988 1.7 QV
Brit01
PostPosted: Thu Sep 12, 2013 2:00 pm    Post subject: Reply with quote
Are the intake valves 92.0 mm or 92.9 mm long?
I've seen 2 versions Confused
S2 33 1988 1.7 QV
eagle3
PostPosted: Fri Sep 13, 2013 1:27 pm    Post subject: Reply with quote
Brit01 wrote:
1 is fine. Why?
Just wondered whether it was belt-related. Can't help with the valve length I'm afraid. Might be something to do with the valve clearance adjustment. Older engines had manual adjustment; later ones(like yours) have pastilles(shims).
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
Brit01
PostPosted: Fri Sep 13, 2013 6:33 pm    Post subject: Reply with quote
eagle3 wrote:
Brit01 wrote:
1 is fine. Why?
I did check my belts and all aligned. didn't slip any teeth
hydraulic tappets here so no lash.
No ticking noise due to broken tappets.
maybe one has collapsed and its not opening (but wouldn't tick)? Could this happen?
I have a few tappets spare luckily. valves are the issue
S2 33 1988 1.7 QV
Brit01
PostPosted: Fri Sep 13, 2013 6:41 pm    Post subject: Reply with quote
Great!
just spoke with my mechanic. very experienced, worked on European rallys etc.
'don't worry about finding valves. we have expert machinist who takes high quality race valves and machines them to the exact dimensions we need'
if it is in fact a valve issue or not a tappet or something.
broken piston ring? maybe
S2 33 1988 1.7 QV
eagle3
PostPosted: Fri Sep 13, 2013 7:10 pm    Post subject: Reply with quote
Hydraulic tappet seized?
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
Brit01
PostPosted: Fri Sep 13, 2013 7:40 pm    Post subject: Reply with quote
yep could be I guess.
But no unusual noises coming from the cam area. dead silent.
collapsed internals so its not lifting the valve?
if it was seized wouldn't hit be hitting the lobe and making a nasty noise?
has a broken tappet before and it sounded like a sewing machine!
all guessing right now. we'll see next week but I am so curious.
I have one spare alfa tappet NOS. and I can buy INA ones here. All in now are INA about 2 years old.
S2 33 1988 1.7 QV
Brit01
PostPosted: Mon Sep 16, 2013 5:29 pm    Post subject: Reply with quote
Anxious day today.
Took her in to have the head removed.
He'll call me once he has it off to see the damage!
Crying or Very sad
S2 33 1988 1.7 QV
fluffyduff
PostPosted: Mon Sep 16, 2013 5:43 pm    Post subject: Reply with quote
Hopefully it's not too painful...
Brit01
PostPosted: Mon Sep 16, 2013 5:45 pm    Post subject: Reply with quote
I don't mind if its a valve job. he knows his stuff and can do that easily.
Don't want it to be a broken piston ring or hole in the piston. I want the pistons to remain in place.
Hope the tappets are fine along with the cams also. (replaced 2 years ago)
S2 33 1988 1.7 QV
johnboy
PostPosted: Mon Sep 16, 2013 5:46 pm    Post subject: Reply with quote
Good luck chap Wink
WODA WE NEED? MORE POWER!!
1999 freestyle superjet
PostPosted: Mon Sep 16, 2013 6:01 pm    Post subject: Reply with quote
Is it really zero compression, or just low? Zero would need quite dramatic damage I would think (and would make a massive difference to performance).
Not done it but I think you could probably change a piston with the engine in place with little more effort than replacing a valve. Head off, sump off, undo big end bolts, slide piston and rod out through the top.
Years ago my father had an oil consumption problem on a Lotus Europa. As a short term bodge he used the Selenia HPX oil (20W60 oil for old engines), which cured the oil consumption. A later engine strip revealed the reason for the oil consumption as a broken piston ring Laughing .
PostPosted: Mon Sep 16, 2013 6:38 pm    Post subject: Reply with quote
This is what I found with zero compression.
http://www.alfa-pages.co.uk/viewtopic.php?t=4426&highlight=valve
Brit01
PostPosted: Mon Sep 16, 2013 6:56 pm    Post subject: Reply with quote
Admin wrote:
compression was about 40 psi at best and was slow to get up to that.
Absolutely no power from #2. remove the HT cable and no difference.
Basically its not firing and its running on 3 cylinders so yes a huge difference in performance.
never saw any oil being burnt though. plug was blackish but not wet at all. just rich soot
yep piston could come out with engine in but if a ring replacement is needed then the difficult part is honing that bore to accept the new rings.
this is normally an engine out job and needs thorough cleaning afterwards.
Lets just hope its a burnt valve and not sealing on its seat properly.
S2 33 1988 1.7 QV
Brit01
PostPosted: Mon Sep 16, 2013 7:40 pm    Post subject: Reply with quote
thanks for the link
yeh maybe it is this. maybe a smaller hole as I get a little pressure while running the engine. maybe a small hole.
S2 33 1988 1.7 QV
eagle3
PostPosted: Mon Sep 16, 2013 7:53 pm    Post subject: Reply with quote
If there's any compression(you did say "no compression" before) then the valve must be closing tight at some stage. Any hole however small would reduce the compression to zero, if not immediately then some short time after.
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
Brit01
PostPosted: Mon Sep 16, 2013 9:17 pm    Post subject: Reply with quote
We did a fast test on the side of the road With the engine running.
Not a leak down test.
If the hole is small there would still be a small amount of compression as it is forced out of the hole.
Unless so big as pictured in the link.
well anyway there is a spark, fuel going in but not producing any power and extremely low compression.
No noises from tappets or smoke coming out.
it does sound like a tractor though coming from the exhaust!
S2 33 1988 1.7 QV
eagle3
PostPosted: Mon Sep 16, 2013 9:54 pm    Post subject: Reply with quote
Is cylinder 1 identical to 3 and 4?
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
kevjtd
PostPosted: Mon Sep 16, 2013 9:56 pm    Post subject: Reply with quote
there's your clue.
burnt exhaust valve or the seat has eroded/moved/cracked
that's where my money would be
Brit01
PostPosted: Mon Sep 16, 2013 10:02 pm    Post subject: Reply with quote
kevjtd wrote:
there's your clue.
great. yeh the noise comes from the carbs and tailpipe.
no news from the mechanic today. hopefully get a call tomorrow.
bets are on then
burnt valve or eroded seat: 1-2
Best to get all valves and guides done while the head is off I assume
S2 33 1988 1.7 QV
Brit01
PostPosted: Tue Sep 17, 2013 7:15 pm    Post subject: Reply with quote
Very weird!!
Just got a call from the mechanic and the piston started working again before he took the head off!!!
Must have been a carbon build up or something!!
S2 33 1988 1.7 QV
Brit01
PostPosted: Wed Sep 18, 2013 2:29 pm    Post subject: Reply with quote
Tensioners were shot! ! Changed them just in time! !
Old pump came out with a fight.
Old plastic rotor! !! Cheap no??
All new going on today.
S2 33 1988 1.7 QV
johnboy
PostPosted: Wed Sep 18, 2013 3:07 pm    Post subject: Reply with quote
Good news Brit and a bit lucky with the Tensioners Wink
Goto page 1, 2  Next
Page 1 of 2
