Header tank level
PostPosted: Mon Dec 16, 2013 6:06 pm    Post subject: Header tank level Reply with quote
When running a 16v engine should the water in the header tank go about 1.5/2cm above the max line when at running temperature Question
Or have I got a problem
Oggie
PostPosted: Mon Dec 16, 2013 7:34 pm    Post subject: Reply with quote
Possibly a failing thermostat, not opening fully?.
PHAT 33
PostPosted: Mon Dec 16, 2013 9:02 pm    Post subject: Reply with quote
I wouldn't worry too much, but just keep an eye on it.
In my (limited) experience of 33s, suds etc the coolant in the header tank tends to run low rather than high...
PostPosted: Mon Dec 16, 2013 9:43 pm    Post subject: Reply with quote
Brand new thermostat.
I know the coolant should be pressurised when running and therefore be a tiny bit higher, but I think this may be excessive?
Worried it could be a head gasket going?
eagle3
PostPosted: Tue Dec 17, 2013 6:03 am    Post subject: Reply with quote
I don't think I would be too alarmed by that. I would if i could see bubbles in the expansion tank.
As long as the radiator's getting hot after 10 minutes or so the thermostat should be working ok(just because it's "new" doesn't mean it can't be faulty ). Smile
In principle if the pressure in the expansion tank gets too high the seal on the cap should open(can't remember the pressure - it's sometimes marked on the cap - about 1.5 bar) and let any excess coolant out through the overflow pipe.
Did you change the water pump as well?
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
PostPosted: Tue Dec 17, 2013 9:16 am    Post subject: Reply with quote
Yes replaced water pump, thanks Eagle.
Engine reaches temperature fine.
Will give car a run today and look for any bubbles.
Joelomint
PostPosted: Tue Dec 17, 2013 1:45 pm    Post subject: Reply with quote
Could be a bit of air in the system after re-filling.. let her warm up, open the header tank, and give the lower hose a few squeezes - assuming you can get your arm down there on a 16v
I find i have to do this every time i change the coolant
SUD 145
PostPosted: Sat Dec 21, 2013 1:23 am    Post subject: Reply with quote
Hi Paul. My '83 Sud runs a cap at 7lb but a S2 33 may be higher. If it lifts a 7lb cap I'd check is there water inthe oil or oil in the water before going to a higher cap. Compression check.....
ZeNiTh-PbArM
PostPosted: Tue Dec 31, 2013 12:23 pm    Post subject: Reply with quote
The level is alvays ~1cm higher when the car is hot.
If the car gets really hot I found it is sometimes impossible to have the header tank full up to the mark in cold condition since it will spill out excess water when hot and then shrink back to below maximum.
zp
PostPosted: Tue Dec 31, 2013 1:50 pm    Post subject: Reply with quote
Think it was air in the system as everything seems to have settled to what it should be after some refilling, but will keep an eye on it. Thanks everyone for your replies.
