Brit01 Gold Cloverleaf
Posted: Fri Jan 31, 2014 5:19 pm Post subject: annoying oil leak! |
Very slight leak but frustrating!
Its on the block around one of the plug holes. Could be from the dizzy shaft, oil filler cap, back plate gasket or plug hole.
I get a slight film of oil around this area after I've been driving hard for a while. Nothing significant and I only top up my oil a little every few months.
I will replace the o-ring on the dizzy to eliminate that possibility. Just hope its not a plug hole or the gasket between the block and back plate. _________________ S2 33 1988 1.7 QV
Posted: Fri Jan 31, 2014 6:10 pm Post subject: |
also if it was the plug I imagine the plug hole would fill up with oil first before leaking onto the block.
It must be seeping from the back plate gasket or dizzy o-ring. _________________ S2 33 1988 1.7 QV
Posted: Fri Feb 14, 2014 10:33 pm Post subject: |
Spent 5 quid on dizzy orings and haven't noticed any further oil seepage!! Not fitted yet!!
Typical!
All dry after the last 200kms.
Fixed itself apparently _________________ S2 33 1988 1.7 QV
![](images/avatars/1934805163520e457b0b628.jpg)
Posted: Sun Feb 16, 2014 10:32 pm Post subject: |
unless you re out of oil! ![Smile](images/smiles/icon_smile.gif) _________________ PHAT 33 |
Bobkelso Alfa Sprint
Posted: Sun Feb 16, 2014 10:38 pm Post subject: |
..I also want only auto-fixing oil-leaks..
..more practical.. ![Very Happy](images/smiles/icon_biggrin.gif) _________________ Alfa 33 |
Posted: Tue Feb 18, 2014 1:47 am Post subject: |
The price I pay for my 300v motul oil it should have some magic healing properties!
Haha _________________ S2 33 1988 1.7 QV
