RFlower Alfa 33
RFlower Alfa 33
Posted: Wed Nov 12, 2014 12:01 pm Post subject: |
I must admit they don't squeal, though _________________ Dick Flower, Nr. Carcassonne. '94 Trofeo 1.4 ie (F), '93 Imola 1.3/1.4 ie (now for breaking) (F), '91 1.7 ie (GB)(spare car), '86 Sprint 1.5 QV (F). '87 VW Syncro camper (F), '73 NSU Ro80 (F), '99 Fiat Seicento (F) |
Posted: Thu Nov 13, 2014 10:13 am Post subject: |
Sounds like a good product.
If you spray the discs and inside the drums with WD40 too you'll also avoid any surface corrosion. _________________ If it aint broke, fiddle with it until it is!
Bobkelso Alfa Sprint
Posted: Thu Nov 13, 2014 10:18 am Post subject: |
..also if they say something like this:
"Where damping lacquer coatings or damping shims
are fitted metal free anti-squeal lubricant is not required.
Only use the metal free anti-squeal lubricant (Mintex CERA TEC®)
in the area of contact of the pad on the guide shafts.
Lubrication is only vital in the area of the contact points
of the pad and on the guide shafts. "
(bur probably you are right, it is still a useless product,
I think putting grease on this contact point will avoid squeal
for about 3 kms, the main problem is the pads material and
the presence or not of damping shims?)
http://mintex.co.uk/wp-content/uploads/2013/10/Mintex-Practical-Tips-EN-WEB.pdf
Ps..have you to degrease brake pads and disks surface
or simply some use will wash them for you? _________________ Alfa 33 |
