Posted: Mon Jun 29, 2015 4:35 pm Post subject: glowing battery light |
Occasionally I get the above. If I reach behind the fusebox and wiggle some wires, the battery charge light goes out.
I looked at the fuse box to find the following
The black wire goes up the right of the dash, is that the offending wire, any suggestions? _________________ x2 33 16v
Posted: Tue Jun 30, 2015 1:09 am Post subject: |
I ran the engine and removed what I thought was the offending block.
It didnt make the battery light come on...? _________________ x2 33 16v
RFlower Alfa 33
Posted: Wed Jul 01, 2015 6:50 pm Post subject: |
The burnt connection quite possibly has something to do with the problem
You disconnected other wires when you removed the block, which could have also affected the light.
Instead of trying to work out how the flaky electric system on Alfa 33's works, I suggest you just replace the connector in the block (you can get them via Ebay) and clean up the tab in the fusebox.
The connectors pull out of the block if you depress the little retaining tab with a piece of stiff wire or a small screwdriver. _________________ Dick Flower, Nr. Carcassonne. '94 Trofeo 1.4 ie (F), '93 Imola 1.3/1.4 ie (now for breaking) (F), '91 1.7 ie (GB)(spare car), '86 Sprint 1.5 QV (F). '87 VW Syncro camper (F), '73 NSU Ro80 (F), '99 Fiat Seicento (F) |
Posted: Thu Jul 02, 2015 4:40 pm Post subject: |
| I'd go with what Dick says Al. Replace that wiring. Even if it doesn't solve the problem it's going to stop you having a mahoosive fire where your beloved 33 once stood. |
Posted: Sat Jul 04, 2015 7:47 pm Post subject: |
Kinghams have had loads of stuff on there since I were a lad.  |
Posted: Mon Jul 06, 2015 8:31 pm Post subject: |
Yeah because there stupidly priced.
Got a fuse box lined up.
Took the car out last night, no glowing light, maybe removing all the connectors and re connecting them helped.
I did have a glowing full beam light though lol. _________________ x2 33 16v
Posted: Sat Jul 25, 2015 12:04 pm Post subject: |
Not had a glowing battery light since and found out the glowing full beam light happens when the connectors on the main lights comes loose. Who needs alfa control panel lol  _________________ x2 33 16v
