galaxierog Alfa Arna
Joined: 12 Jun 2003 Posts: 14 Location: Birmingham, England
Posted: Sat Sep 20, 2003 6:21 pm Post subject: ignition on cold starting |
My car will not start when cold. My temporary fix is to spray petrol into the air cleaner box which eventually starts it but I realise this may eventually backfire(no pun intended). Alfa 33 1.5ie 1990 Bosch airflow meter Cold start temp sensor changed. This temporarily fixed the problem but it has now come back to haunt me. I have to use my 67 Galaxie on British roads. It doesn't quite corner as well as the Alfa, please help me. |
Posted: Sat Sep 20, 2003 7:19 pm Post subject: |
I presume this is a Jetronic injection equiped car. Think they use a cold start injector to richen the mixture. My guess is that the cold start injector isn't being triggered.
Posted: Sun Sep 21, 2003 9:26 pm Post subject: |
Only just replaced this about a month before the problem started again could it really be that again are they that unreliable? |
Posted: Tue Sep 23, 2003 8:18 pm Post subject: |
After having exhausted other options could a loose connection from the starter motor which has also been reconditioned recently cause a problem. |
Posted: Thu Sep 25, 2003 5:27 pm Post subject: |
Wouldn't think the starter motor would cause this problem. Disconnect the cold start connector, put the end into a jar and crank the engine (get someone else to do that while you hold the injector) and check that it works.
Careful though as if it does it stands a chance of squirting high preasure fuel all over the place.
Posted: Sat Sep 27, 2003 9:20 pm Post subject: |
Something strange has happened After our expert electrical friend a few doors away looked at the car it has started working again. He says that all he did was make sure things were still connected and that he pushed the vacuum pipe home it seems as though it may have been loose. Does this sound possible? |
