Fibreglass race car panels for series 2 - wide arches etc.
Goto page 1, 2  Next
Edward
PostPosted: Thu Sep 25, 2003 9:47 pm    Post subject: Fibreglass race car panels for series 2 - wide arches etc. Reply with quote
Hello everyone,
You may be interested to know that I have the racecar fibreglass sets for the series 2. The panels replace the front wings, the rear wings are cut into the rear panels and the rear door skins come as a complete panel. The lightweight bumpers are very close copies of the veloce bumpers but are slightly strengthened and also slightly wider. This is due to the fact that the wings are wider in a similar way to the Integrale wings. They are a lot lighter. The bonnet is self supporting but effectively is a skin. It is made from fibreglass as is strengthened on the inside. The boot lid is similar to the bonnet and I had one on my last road car. It is staggering the difference in weight.
I have had the moulds for some time and used to make the panels myself for the race car fraternity, but due to pressure of work and mountain biking I now have the panels made for me. As a result they are not cheap. Interestingly though they also go onto a road car. My last one had them fitted before I crashed it heavily into a tree. I salvaged all the panels and they are now fitted to my 1830cc stripped out trackday car.
For anyone wanting to rally and lighten the car I also have the standard fibreglass door skins. These are quite easy to fit and provide great benefit to lighten the car.
If you are interested let me know and I will try and send you some details.
Edward.
The faster the better.
ak8635
PostPosted: Fri Sep 26, 2003 12:01 pm    Post subject: Reply with quote
Hi Edward,
what kind of reduction in weight could you succeed?
Any examples?
thanks
A112
johnboy
PostPosted: Fri Sep 26, 2003 7:51 pm    Post subject: Re: Fibreglass race car panels for series 2 - wide arches et Reply with quote
Hi edward
how much money are we talking to lighten my alfa? i have s2 with a 16v which i put in Cool and would love to make it go abit quicker,as for spraying i do it for a living.you say the front wing's are like the integrale,which is'nt a bad thing,did you widen the track on your car? so it did'nt look out of place.let me know
all the best
john
WODA WE NEED? MORE POWER!!
1999 freestyle superjet
alfafan
PostPosted: Sat Sep 27, 2003 9:55 am    Post subject: Pictures... Reply with quote
Can you post some pictures?
If not, can you mail them to me?
carlosprint@clix.pt
You say it is similar to the Integrale...
I“m curiose....
I also have an Integrale, so I would like to compare....
Best regards
Carlos Oliveira
Edward
PostPosted: Sun Sep 28, 2003 12:26 am    Post subject: Reply with quote
Regarding the lightening of the car - it is a little difficult to determine - except to say that when you pick up and original bonnet for example there is no way at all that you can hold it out at arms length - with the fibreglass ones this is reletively easy. It is the same with the boot lid which is incrediably heavy. There is also a signifiant difference in the comparitive weight of the wings, not to mention the door skins and then the bumpers. I am trying to finish my car off so I can take it to the friendly breakers yard and put it onto their weigh bridge. With a few other minor weight saving measures I anticipate a rough weight saving somewhere in the region of 100kg. This may sound alot for a car that weighs some where between about 800 to 1050 kg depending on the model but the comparitive weight of the part is so great. I feels so good just to take the boot lid off and through it to one side and realise that you are never going to haul that around again. Just to take the boot lid off the car really does take two people to be safe.
One I have some weigh bridge numbers I will let you know.
Edward.
Edward
PostPosted: Sun Sep 28, 2003 12:35 am    Post subject: Reply with quote
Hello John,
Errr.... it isn't just front wings that are similar in shape to an Integrale it is the rear also. I guess I didn't make that clear in my original e-mail. The wings are not overdone - I would suggest that they are similar to the series 2 integrale not the final version. In answer to your question regarding spacing the front wheels - yes - on my last car with 16" revolutions I did use a space between the wheels and the hubs. This made the wheel fill out the arch nicely. At the back I put the spacer between the stub axle and the shell. I had to get some longer bolts for the front but this was no problem.
The race boys cut and weld together the lower struts etc or have longer rose jointed extentions but mine worked well with spacers for years that I never thought to change it.
Hope that answers your question.
I will try and add some photos.
Edward.
Edward
PostPosted: Sun Sep 28, 2003 12:37 am    Post subject: Reply with quote
John,
You did ask how much things cost - I will look up the prices for the various parts soon and let you know.
Edward.
johnboy
PostPosted: Sun Sep 28, 2003 4:16 pm    Post subject: Reply with quote
Hi Edward,
thank's for getting back to me,look forward to hearing from you.
all the best
john
johnboy
PostPosted: Fri Oct 03, 2003 7:52 pm    Post subject: Reply with quote
Hi edward,
any new's on the kit front? plus i have a photo of one of your kit's,they look the nut's,thought i had one in my gallery.
all the best
john
Edward
PostPosted: Sat Oct 04, 2003 10:41 pm    Post subject: Reply with quote
John,
I have some photographs that I would suggest might be good to load onto the site. Do you have any idea how to do that. You mentioned you had one in your gallery. Could you point me to it as am always interested to see what people have done to their cars that have bought the kits.
The prices are
1 Full set of replacement wings, front and rear veloce bumpers - £820
2 Bonnet and rear boot lid as a pair - £150
3 Bonnet seperately - £100
4 Boot lid seperately - £100
5 Individual front wing - £125
6 Rear door skin section and rear wheel arch each side £150
7Front bumper - £175
8 Rear bumper - £150
9 Ancillaries e.g. bonding agent - prices on request.
I also fit the kits for people and would suggest this is done quite reasonably as it is a bit of a labour of love.
Hopefully I will get some pictures onto the site soon - once I have worked out how to do it. I will also try and do a web site but I guess one step at a time.
Edward.
johnboy
PostPosted: Sun Oct 05, 2003 9:30 am    Post subject: Reply with quote
The prices are
Hi edward,
thought they would be alot of dosh Sad
don't think i can spend that kind of money on the car,in one hit.it's a shame as the photo i have of your kit look's the nut's!!! but i'm very interested in the bonnet and boot,as they are the heavyest bit's.i take it all the fixing point's are on them? can you find out how much to post them,as i live in margate so it's abit of a trip.as for the photo i have,if you send me your e-mail address i can send it to you,as i don't know how to post photo's aswell.
all the best
john
Toad
PostPosted: Tue Nov 11, 2003 10:21 pm    Post subject: Pics Reply with quote
And still no Pic's ??? please email some to me toad@alfaowner.com
Shift for Brains
Toad
PostPosted: Tue Nov 11, 2003 10:24 pm    Post subject: Pics Reply with quote
Shift for Brains
Edward
PostPosted: Wed Nov 12, 2003 12:16 am    Post subject: Reply with quote
Dear Toad,
I tried to set up a website so that I could direct the Alfa Pages to some pics, but for some reason nobody seems to be able to offer some easy ways to achieve this. I could, I suppose, pay someone to set up a website for me but I guess also that my children need to eat so.....
I will send you a couple that I think I can sent relatively easily on normal e-mail.
Edward.
Toad
PostPosted: Tue Nov 25, 2003 1:41 pm    Post subject: Reply with quote
email me the pic's and I'll post them up here for all to see
Shift for Brains
PostPosted: Tue Jan 20, 2004 9:21 am    Post subject: Fiberglass hood etc Reply with quote
I'm very intrested to see pics of those. Could You please give a link.
Could get rid of 2 rusty parts with fiber hood and bootlid Rolling Eyes
TimoJ
Edward
PostPosted: Sat Jan 31, 2004 11:36 pm    Post subject: Reply with quote
Timo,
If you let me have an e-mail address I will send you some photos.
Edward.
PostPosted: Wed Feb 18, 2004 11:40 am    Post subject: Hood Reply with quote
Sent You a pm including mail address. Waiting anxiously.
TimoJ
James Granger
PostPosted: Tue Mar 09, 2004 8:45 pm    Post subject: Reply with quote
Where's the pics?! Smile
Wizz
PostPosted: Fri Apr 16, 2004 9:46 am    Post subject: Reply with quote
Oh my! That sounds so neat,
Would love to see some images. Very Happy
If nobody else is capable, I would love to host them. Mail me at wizz@baka.dk and I'll post them here.
Which reminds me I ought to put together the images from my gearbox overhaul, and scribble down some text to go with it. Embarassed
//Wizz
Alfa 33, 1.5 IE (1992) (Series 3)... now with 1.7 IE Very Happy
View user's profile Send private message Visit poster's website MSN Messenger
Wizz
PostPosted: Fri Apr 16, 2004 6:09 pm    Post subject: Reply with quote
Johnboy just sent me this:
Shocked Shocked
Wrouuuummm!! Evil-looking. Razz
Anyway, if anybody has more, I'll be happy to host them.
My hosting-thingey is free, since it runs off a laptop of mine at home. The bandwidth should be sufficient for handling pictures such as this.
I wish I had the kinda money / time to offer on a bodykit like that. ^_^
//Wizz
alfaqv33
PostPosted: Mon Apr 19, 2004 12:48 pm    Post subject: and something like this?? Reply with quote
Hi guys, ik come from holland and this is mij car on the picture. Check my rear wing!!
Wizz
PostPosted: Mon Apr 19, 2004 3:22 pm    Post subject: Reply with quote
Hah, nicely done.
Mean-looking, thats for sure. Maybe a bit too agressive to my liking.
What airplane did that king-size spoiler come off? Wink
That's a Lester front spoiler, and eye-lids, right?
Anyway, looks like your 33 is in very good condition, at least on the outside. Congratulations. Very Happy
//Wizz
alfaqv33
PostPosted: Mon Apr 19, 2004 4:05 pm    Post subject: Reply with quote
thank you for replay. The spoiler is very unique, only 9 spoilers are left. 20 were build. The spoiler looks originel with the big cloverloaf at both sides.
The front spoiler is a Lester one, the eye lids are home made. My car is in good condition, but my car is and will be changed a lot more than what you only can see. I have al lot of plans, i shall post more pictures soon.
24 and 25 april there is a big meeting for italian cars in belgium, for more information you can look on www.italfest.com. I will be there also.
Sorry for the bad english i wrote........
James Granger
PostPosted: Tue May 18, 2004 10:19 pm    Post subject: Reply with quote
Did you just buy the car, or are you currently selling it? I recently saw an identical car for sale in Holland on alfaforum.nl.
BTW, is it lowered by 30 mm? I'm just curious for an indication as I'm having my own 33 lowered soon. Wink
Goto page 1, 2  Next
Page 1 of 2
